Results 1 to 20 of 23
    Member lrader99's Avatar
    NW Georgia
    flat black
    Intake Manifold Comparison
    ok so heres what ive been looking at and im not finding any flowcharts or spec sheets for these manifolds
    1. BBK SS1 intake
    2. Weiand Lingenfelter intake
    3. Professional products intake
    any help would be greatly appreciated thanks
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    theres not really any charts out there.
    im not sure of what the PP makes numbers wise, but i know the other two dont really beat out the good ole ls6 intake.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    LS1 land
    yea i would stick with the LS6 for sure
    Junior Member NIGHTMAREWS.6's Avatar
    Ocean Springs, MS
    TRIPLE BLACK
    2002 WS.6 Build #12425
    The PP intake flows about the same as the LS6 intake, and slightly better in upper rpm range, there's a large post about it on another forum.
    Rollo Tomassee AKIRA's Avatar
    Outside the box
    This is the FIRST time Ive ever heard of some PP intake.
    I would stick with the much more proven LS6 intake personally.
    Painted manta stripe
    Member Huskerz1's Avatar
    99 SS Vert M6
    LS6
    NW Georgia
    flat black
    i think thats my problem is ive never really seen any flow charts for any of the Intakes...I mean im sure the Weiand intake must be good, else lingenfelter wouldnt be using it....and ive heard good things about the BBK intake, even though it flows similar to the stock composite with a metal intake you have the ability change ports around if you wanted to...and i really just dont know much at all about the professional products manifold
    LS1 land
    yea these could slightly outflow the LS6, but you definately don't want a metal intake manifold. Polymer (LS6) is much better. Once your engine warms up the manifold becomes heat soaked. Heat= enemy of horsepower.
    ORNGP33L 1BADDLS1's Avatar
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    LS6
    the downfall for intake flow with the LS6 isnt the ports but the 78mm which they all have
    only options are LS6 or FAST90 (and of coarse FAST only if set up sustains the $$$)
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    LS6 and 78mm
    I went with the proven LS6 and 78mm FAST TB. Seems to be a significant power increase and torque. Can feel a difference.
    Arkansas
    99 Trans Am
    I will be buying the 96mm Professional Products manifold along with their 96mm throttle body within the next couple of weeks to prepare for finally throwing on my heads and cam. Will be paired with a set of CNC machined stage 2 heads with manley valves/springs/retainers and a 224/231 581/589 cam on a 114 LSA. Hoping to see good numbers so maybe I can cut back on the spray a little finally Ill post a review of the PP Manifold though, I dont mind being the test dummy and as stated before thier 85mm version puts the same numbers as the LS6 for about 2/3s the price brand new.
    NW Georgia
    flat black
    im doing the same. except im using the 85mm version cause im going to use my ported and polish throttle body, set of ported LS6 heads and a ZO6 cam...im going to have nick williams do the tune and we will see how it goes from there...the only thing i have found that i really dont know about is that the composite manifolds have an accumulator built into the fuel rail.
    Arkansas
    99 Trans Am
    well if yours gets done before mine i will be eager to here the results. are you installing it yourself?
    NW Georgia
    flat black
    oh yeah...ive done all my own work. after this i tihnk the only thing i could do to the car is a power adder...nitrous or some sort of boost...or go with a bigger heads and cam package.
    Arkansas
    99 Trans Am
    ok good. can you just let me know if you run into any problems with the install or if any additional parts were needed
    NW Georgia
    flat black
    from what they say it comes with a new TB gasket and intake gaskets and hardware but i also ordered new injector o-rings. i dont want to deal with a leaky injector. the only thing im unsure about ill probably end up calling the PP but i dont know if theyre gonna send torque specs for the bolts...i guess we will find out on friday....by the way. nice hood man.. i loved the fitment when i put mine on. unfortunately my car got vandalized and i havent quite decided what color im going to paint the whole car and i like it flat black i may just spray it flat black permanently
    NW Georgia
    flat black
    by the way what have you used for a nitrous set up and are you going to go with a direct port setup now that your going to have a metal manifold? did you have to retard the timing in order to run nitrous. ive got my ZO6 cam stuck in 4 degrees advanced i was really thinking of sticking a 150 shot in the car though
    Houston
    Red/White
    60 Corvette w/ LS2
    Quote Originally Posted by juiced99ws6 View Post
    I am very interested to see how the Professional Products manifold performs. I would like to put one on my LS2 in my 60 Corvette for the hp and looks, but I have not been able to find anyone with experience using one and a lot of people are concerned about the heat soak. As fast as the air moves through the intake I don't think it has enough time to heat up significantly, but I will be looking for your results.
    Good luck with it and keep us informed.
    Junior Member Filthy 150's Avatar
    Houston
    green
    1997 Corvette
    What about a LS2 over a LS1.
    Any benefit?
  1. LS6 intake manifold and 227 Intake runners
    By IT_SS in forum Internal Engine
    Last Post: 07-07-2009, 02:11 PM
  2. Factory Cast-Aluminum Intake Manifold Comparison -
    Last Post: 02-09-2009, 08:10 AM
  3. Who has a BBK intake manifold?
    By ArcticLS1 in forum External Engine
    Last Post: 02-20-2006, 12:41 PM
  4. Intake Comparison
    By mavrikZ in forum Firebird / WS6
    Last Post: 02-17-2006, 08:42 PM
  5. Intake Comparison
    By mavrikZ in forum Appearance Section
    Last Post: 02-15-2006, 08:47 AM
