Results 1 to 10 of 10
02-02-2007, 05:54 PM #1
Car Surges When Idling Help Please!
I bought a 98 z28 about 6 months ago.The car ran excellent but a few weeks ago it started to idle stragely. It idles ok a few secs then surges(like a rough idle) then back to normal then surges again over and over. It has perfect acceleration when I give it gas and runs fine but the idle problem is bugging me. The car has 66,000 miles on it and I know the guy never put plugs on it or wires.The check engine light isnt on either.Can anyone give me some advice on what to do about it/look for?? Has anyone of you had this problem?
Thank you----mike
02-02-2007, 11:25 PM #2
Replace the plugs and wire, then inspect all vacuum lines for dry rot and cracks.
02-02-2007, 11:41 PM #3
Ill do those things first.thanks-mike
02-03-2007, 04:40 AM #4BLT4SPD
- Jan 2007
- north carolina
black (SS), red (57)- 2002 cam SS. 57 Pro St
Also make sure that your air filter is clean and all of the throttle body crap is clean. I had a LT1 that did the same thing (idle surge) and all it needed was a air filter and the throttle body sprayed and cleaned.
02-03-2007, 05:10 AM #5Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
Clean your maf while your at it
02-03-2007, 11:01 AM #6
I will do it. This site rules. I get so much good info. any time I have a problem. Sure do appreciate you help fellas---mike
02-11-2007, 03:49 PM #7Junior Member
- Jan 2007
- baden pa
surging
I had a 95 Z28 that did that, it was either the mass air had slipped off slightly or the IAC needed cleaned.GOOD LUCK!
02-11-2007, 06:48 PM #8
Do I take the MAF off the car to clean it?
02-11-2007, 10:52 PM #9We'll be back...
- THE SWAMP
Yes, take it off to clean it. Use non-residue electrical cleaner. Clean the IAT sensor while you're at it. Also, change your fuel filter.
02-12-2007, 10:39 AM #10
Info. is much appreciated. Thanks again---mike
Romney Surges Ahead Dramatically in New Polling...
By wileyCoyote in forum Political / Debate ForumReplies: 2Last Post: 10-10-2012, 03:32 PM -
rough idle and surges erraticaly intermitten
By 1QWKZ in forum Computer & TuningReplies: 6Last Post: 10-03-2010, 09:32 AM -
Idling at 650 to 750 RPM's
By 9t8z28 in forum External EngineReplies: 4Last Post: 10-31-2006, 06:25 AM -
Engines surges and loses power
By koolaid_kid in forum External EngineReplies: 2Last Post: 05-25-2006, 10:26 PM -
My Baby Surges At 50mph
By kaos2700 in forum General HelpReplies: 4Last Post: 01-25-2006, 09:56 AM
