Results 1 to 20 of 20
    Junior Member formula1804's Avatar
    Peoria IL
    2001 Camaro SS Red M6
    Bright idea or just madness??
    I have begun to buy the parts necessary for a t top conversion from a hardtop. I was wondering what all of you thought of this, and if you have any advice or pointers that would help me out...
    Don't mean to sound negative here, but if you want a ttop, buy one. I have heard the conversion isn't the funnest thing to tackle, JMO though. If you do choose to do it, good luck with it.
    Painted manta stripe
    Rhode Island
    Arctic White Hardtop
    '98 Formula M6
    Sounds like $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
    TX
    2002 T/A WS6
    i havent heard to much about the conversion kits but i wouldnt think it would be all that great i personally would be more worried about how it fits and leakage
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Why not do it. If you mess it up you can always try to make it into a vert!
    Aug 2006
    Madrid, Iowa
    02 trans am ws6
    check back threads somebody did this and had pics. It was awhile ago though.
    It takes serious nads to cut into the roof of a car. Aren't the hard tops a shade lighter than the t-top cars anyhow not to mention a little more rare.
    Peoria IL
    There's not that much weight diff. You are actually losing a couple of pounds by cutting off a ton of metal from underneath. actually i have the site i will be following to do this...http://members.fortunecity.com/gripe...onversion.html
    as for buying a t top car.. i have already built this car to where i want it, and now i want t tops, simple as that.
    For all the parts it was less than $500, and i already have all of the tools, so its not very expensive secret..
    Marylandistan
    2001 Trans Am (sold)
    Here's an article that may be helpful.
    Peoria IL
    Thanks for the url INMY01TA, much appreciated.
    Marylandistan
    Quote Originally Posted by formula1804 View Post
    No sweat.
    Stang Reaper LS1Formula01's Avatar
    Missouri
    Pewter Metallic (1of?)
    2001 Formula M6(1 of 225)
    I would have just looked for a t-top car in the first place, because what if you f**k it up? Isn't much choice to turn back now is there? just my opinion.....
    cement head 00ws6m6's Avatar
    Aug 2006
    the ocean state
    2000 formula ws6
    simply put [madness] good luck post some pics of the install..
    98T/Aformula
    Guest
    It didnt come with t-tops so I would leave it how it came, but whatever float your boat. Good luck...
    WI
    Blog Entries
    1
    Quote Originally Posted by LS1Formula01 View Post
    You missed my post. If he screws up on the t-top conversion he can just go for a vert!
    2000pontiac6
    Guest
    Sooo much more involved with a vert i've never heard of someone attempting this.
    Quote Originally Posted by Hot Black Trans-Am View Post
    There are a bunch of threads on doing this just do a search. Actually i think the hard tops are much more rare. The only thing i'd consider doing if i had a hardtop is possibly doing a taga top. I never see hard tops but a targa would be badass
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Did it to my friend's Z28 and he didn't have the nads. He called me up, I went over, he gave me the sawzal and walked away It's not as bad as people think and the sealing is actually better than stock. Once you make the first cut, it you forget about the mayhem you're causing
    Member wabmorgan's Avatar
    Feb 2006
    Objects in mirror are losing
    Artic White
    96 Formula Firebird
    I've looked at the sites on it. It doesn't seem too bad IF you know how to use the tools involved.
    As for a Targa Top.... cutting out the T will be very bad on the structure of the car.
    The 4th gens were engineered as a T-top. Cutting out the bars to do the T-top conversion does not effect the structure of the car.
    2000pontiac6
    Guest
    Quote Originally Posted by wabmorgan View Post
    You would just need to add some more structural support. There was someone that did it a while back. Subframe connectors would be a must i'm not sure whatelse
    Peoria IL
    as i said before i have this car BUILT, it already has sf connectors, i just want t tops.
  1. Bright Idea: Crimson Trace Lightguard
    Last Post: 03-28-2012, 03:00 PM
  2. '04-'06 GTO HID Headlights - Bright Idea
    Last Post: 11-19-2010, 07:10 PM
  3. Good Idea? bad idea? zboner's trade off
    Last Post: 11-27-2006, 11:19 PM
  4. Good Idea/Bad Idea..? be gentle
    By EREBUSS in forum General Help
    Last Post: 09-14-2006, 02:45 AM
  5. good idea? bad idea? Fiance's Bday gift...
    Last Post: 08-23-2006, 05:39 PM
