    South Dakota
    1999 Camaro Z/28
    Exclamation Need Suggestion..3.73's or 4.10's
    I own a 99 Camaro Z-28 M6 and i was going to get different ratio gears but not sure if i should get 3.73s or 4.10? what would you get plz help
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    Unless you go to the track a lot I would not go over the 3.73 . You can still get decent mileage with 3.73 and get good pickup. One thing also with 4.10 is you better have the ability to adjust your suspension. Depending on your mods I have heard many say they went to 4.10's and can't get traction. Just my 2 cents.
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    4.10's
    Member Z28LS1's Avatar
    New Jersey
    1999 Camaro Z28 M6
    im in the same boat as you, i have a 99 z28.. i've been reading up, and i would suggest you get 3.73s- they save gas, you probably have 245 tires and won't get that much traction anyway (like me), and the 4.10s put a lot more stress on your rear... i've read our rears arent that strong. Any other inputs are appreciated since i might be buying new gears too
    Canby, Oregon
    1999 Camaro SS-M6 #1775
    for drag racing, use 4.40s.
    for the street and drivability then use 3.73s.
    Member pocheasy's Avatar
    Feb 2007
    USoA
    Ive got a set of 3.73's still in box, let me know if your interested. I have to put the mod brakes on
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    I'm in the same boat as you are.....deciding between 3.73, 3.90 or 4.10 for my 2002 M6 Camaro SS. I'm leaning towards SLP 3.73s....from others I hear they are quiet, offer a noticeable performance increase and don't have a terrible effect on gas mileage.
    2002 Camaro SS M6, 2.5 PRC 5.3L heads, TFS 228/230 cam, FAST 92, bolt ons + a 10 lb bottle in the back.
    1989 Corvette L98, A4, Full bolt ons, etc.
    Member jimmy77611's Avatar
    Feb 2007
    Here
    2000 Z28
    honestly, I went from a 3.42 to a 4.10, and could feel just a small performance increase. You should have a 3.42 already, so going from a 3.42 to a 3.73 to me seems like a waste, considering the high cost of doing so, from my past experience.
    South Dakota
    1999 Camaro Z/28
    Alright thanks for the input. Think i'll pry go with the 3.73s because my car don't see the track alot. Besides I been hearing 4.10s dont hook up unless you got good suspension, which I haven't got to yet.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    3.42s are plenty for somone that dosnt go to the track often..our cars have tourqe across the board..whats the performance increase even from 410s???? 2 or 3 tenths at the track???? put some headers on instead ..keep the gas mileage and driveability and still gain those 2 or 3 tenths
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    I'd save the money for a 12-bolt or 9-inch...
    Feb 2007
    Atlanta
    2002 Camaro SS
    I couldn't decide between 3.73s and 4.10s, so I went with a Motive 3.90. My car is a daily driver and I wanted something to add a little more punch for playing around on the streets (already taken care of the headers, intake, exhaust, tune, etc.). I heard that Motive makes a quality gear and they don't whine a lot like the Richmond's.
  1. Question: Suggestion for new exhaust?
    By Hmw717 in forum V6
    Last Post: 05-31-2016, 04:29 PM
  2. Help: Need suggestion on a 6.0L build
    By Cdub270 in forum General Help
    Last Post: 05-10-2014, 03:36 PM
  3. dd suggestion
    By bluehawk2000 in forum Almost Anything Goes
    Last Post: 01-25-2010, 11:37 AM
  4. Have a suggestion.......
    By clg82 in forum Request and Feedback
    Last Post: 02-26-2008, 09:22 PM
  5. just a suggestion...
    By NE98LS1 in forum Request and Feedback
    Last Post: 01-09-2006, 08:43 AM
