    doylestown, Pa
    SILVER
    2004 CTS-V
    Home made boxed LCA's
    Hey, just thought I would share this with all of you. These are stock LCA's that I put on my Camaro after I decided to modify them. I already did this to the LCA's on my BBC Chevelle and it made a hell of a difference especially in the handling department. Basically I took the stock control arms and purchased a 12 gauge sheet of steel from Home Depot for $9. I then cut it out in 2 pieces and welded it onto the bottom of the LCA. This really tightened up the back of the car. It would have turned out much nicer if my welder wasn't overheating. After I smoothed out the welds, well, I think it turned out pretty nice. Anyway! Check em out!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    nice work
    a guy made some for my car too, they are bad ass!
    doylestown, Pa
    SILVER
    2004 CTS-V
    How did he do it?
    Most are made from alum.(or another alloy) stock with threaded (and therefore adjustable) rod ends. Members make panhard bars in the same way.
    I personally like rod ends > Poly bushings > rubber bushings.
    I have a need for speed! jigger1166's Avatar
    Standish,Maine
    Artic White
    00 SS Vert.
    Cool
    I know by boxing the arms, it makes them stiffer. But, does it change the handling, and can you really feel the difference?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by jigger1166 View Post
    Heck yeah, it changes the handling. On my 98Z when exiting a turn and getting into the throttle, you could feel the rear shift and twist before it would break loose. Now, after installing them, there is less shift and twist. Well, alot less. Its made the car more predictable. I can control the rear better with the throttle now.
    I did the same thing on my 3,800LB. Chevelle. Its every bit worth the $9 and 1-1/2 hours of labor.
    Standish,Maine
    Artic White
    00 SS Vert.
    Cool, I can't wait to do it, and try it.
    JIGGER RACIN'
    2000 Camaro SS, vert., auto., LS6 intake manifold, SLP lid, K&N filter, SLP LoudMouth II, C5 Z06 replica 17x9.5 rims
    1/4 mile time = 13.310 sec. @ 105.22 mph, 2.051 60'
    http://www.cardomain.com/ride/2939958
    http://i158.photobucket.com/albums/t...amarolaeft.jpg
  1. home made 04 gto cai
    By jjc239 in forum GTO
    Last Post: 03-10-2011, 11:01 AM
  2. home made jet engine
    By Toyota h8r in forum Multimedia Section
    Last Post: 04-28-2007, 03:43 PM
  3. Pizza I made at home
    By Nastyfoot in forum Almost Anything Goes
    Last Post: 11-04-2006, 11:32 AM
  4. my home made t top shades
    By sgt0704 in forum Appearance Section
    Last Post: 08-05-2006, 08:56 AM
  5. home made pic. video
    By 2004GTO in forum GTO
    Last Post: 10-15-2005, 08:28 AM
