Thread: 18 x 10 and lowered?
01-24-2007, 03:22 PM #1
I was wondering if I got American Racing 18 X 10 rims with a 41mm offset and I already have the Pro-Kit but just ave not installed it yet. Should there be any problems?
01-25-2007, 06:50 AM #2
01-27-2007, 03:18 AM #3
I know when it comes to lowering, you may want to in vent in an adjustable Panhard Rod. The axle moves somewhat when the car is lowerd. With larger rims (not sure how wide yuor going) oyu could have rubbing issues. The off-set sounds right but id have to do some digging. I myself was looking at some 20" rims and they were 225/35-20" (20x8.5) with a 35" offset. But 20's are pushing it. If you stay with the same tire diameter and fill it with a bigger rim, there should be no real problems.
02-06-2007, 06:11 PM #4Junior Member
- Jan 2006
- T-Town
silver- 02 Pontiac Trans Am WS6
I have the prokit with 19x11 and the only problem I had is when I had people in the back (first and only time) and was accelerating around a turn. Other than that no problems...But I also upgraded my suspension.
good luck
eddie2002 Trans Am WS6 408ci Stroker Motor
150 Shot NOS Pacesetter Long Tubes
Magnaflow Exhaust Eibach Prokit
19x10 fronts, 19x11 back CCW Wheels
(2) 12 Kicker Squares 1400watt Kicker 2 channel
02-07-2007, 07:55 AM #5Crazy Canuck !
- Jun 2002
- Montreal, CANADA
doing some calculations, it'll fit perfectly.
I have 17x11 on all corners w/ +50mm and clears fine... you'll clear even more... and no need to massage the inner fender.Eugenio_SS
02-09-2007, 12:40 AM #6
18x10.5 wheels in back
285/35 Nittos
Eibach Pro-kit
Had to roll the rear fenders in just a bit, and then wahlahh!!
After about a year or so, when the suspension started settle, I had to lift the rear suspension a tad to keep the tires from rubbing the inner fender. The 2nd pic shows where the rubbing started.
02-09-2007, 06:20 AM #7
Yes the Eibach Pro-kit lowers a little to much imo.
That is why you get the rubbing with a wider tire.
02-09-2007, 08:49 AM #8
Yeah, that was my concern. But I wanted as much rubber back there as possible, while still maintaining the car's low profile. By raising the suspension a bit (the smallest spacer I could get), I was able to avoid having to hammer-out the inside of the wheel well, like others have done.
can i run 315's on a lowered ws6
By onebadassws6 in forum Wheels and TiresReplies: 2Last Post: 07-19-2010, 10:36 PM -
BEST for Traction? Lowered vs. Not Lowered
By MrMasterCraft in forum Suspension and HandlingReplies: 4Last Post: 02-12-2010, 09:19 AM -
02 ss lowered need help...
By camaroboy 14 02 ss in forum Camaro / SSReplies: 4Last Post: 08-31-2009, 05:45 PM -
1' lowered 02 WS6 What's best?
By JeremyRay in forum Firebird / WS6Replies: 10Last Post: 03-09-2007, 12:43 PM -
SS self lowered
By RWB in forum Suspension and HandlingReplies: 7Last Post: 09-07-2006, 11:52 AM
