Thread: vibration problem
01-24-2007, 10:20 AM #1Junior Member
- Jun 2006
- tx
vibration problem
Why does my center console vibrate so much above 80mph? Under 80 its normal but once I go past 80 it vibrates like crazy.
2000 LS1 A4 3.42's SLP(Lid, cold air induction, maf, LS6 intake with egr) Flowtech longtube headers with ory pipe, 3 inch exhaust with a flowmaster, stock tips, 3500 TCI converter, UMI(adjustable tunnel brace mounted torque arm, lower control arms with reloc. brackets, panhard bar, sfc's).
01-24-2007, 10:55 AM #2
Might need a new trans mount unless it's your driveshaft. I'd tackle the trans mount first since it's the cheaper of the two.
01-24-2007, 12:01 PM #3Junior Member
- Jun 2006
- Boise
white- 1998 Trans Am
i agree with the trans mount... I just did mine... the rubber splits down the middle and causes vibs, especially when accelerating at highway (or above) speeds....
01-24-2007, 05:20 PM #4Junior Member
- Jun 2006
- tx
This only started happening right after I installed my UMI suspension parts.
01-25-2007, 06:42 AM #5Junior Member
- Jun 2006
- Boise
It looks to me that you may have created your own problem... your gonna
have to just mess with the adjustments untill its right...
01-25-2007, 06:44 AM #6
the factory parts are built to reduce driveline vibrations transmited to the body.You removed that feature.
01-25-2007, 08:29 PM #7Junior Member
- Jun 2006
- tx
What shoud I adjust?
01-25-2007, 09:46 PM #8Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
its bolted directly to the chassis. its going to transfer more noise than before. my spohn does the same thing.
vibration
By jsmith564` in forum General HelpReplies: 213Last Post: 02-25-2012, 04:50 PM -
Help: Bad Vibration
By 2001TransAm in forum DrivetrainReplies: 12Last Post: 11-24-2009, 06:42 AM -
Driveline Vibration Problem
By AborTivE in forum Manual TransmissionReplies: 8Last Post: 01-26-2009, 09:05 AM -
What is this vibration
By 01ws6er in forum DrivetrainReplies: 0Last Post: 11-18-2007, 09:14 PM
