Results 1 to 11 of 11
Thread: Intake cutouts
    Member Mr Z's Avatar
    Idaho
    1998 T/A A4
    Intake cutouts
    I have the SLP hood on my bird and i dont like all the baffels. But it rains and snows through the year. So I was thinking of some ram air doors like the old school pontiacs have. My question now is, what's the best way of fabbing some up? I just want black flaps that seal shut at the flip of a switch or a pull of a cable.
    i think your air filter should do a pretty good job at preventing anything from getting in, man. Those baffles are there for sound deadening.
    Member Thorazine Shuffle's Avatar
    Indianapolis,Indiana
    2000 WS6 A4
    First off I would NOT trust my air filter to keep water out of my engine. (Ever hear of hydrolock???) Second the baffles he is talking about are in the hood, not the air box. So they are NOT for sound deadening.
    Truth be known, you aren't going to pick up much if any HP with this mod. If you do a search there are many people out there that have just removed their baffles... Good Luck
    386HP 373TQ jwindbigler's Avatar
    San Diego...Michigan originally
    1999 Trans Am 5.7L
    I removed mine, but I am not in a climate where you need them. It rains, snows, sleets and hails up there in boise. So I wouldnt remove them if I were you. No need.
    STL,MO
    [QUOTE=third_shift|studios;567645]i think your air filter should do a pretty good job at preventing anything from getting in, man. Those baffles are there for sound deadening.[/QUOTE]
    +1
    1999 Trans Am 5.7L
    Its on the damn hood. The "baffles" that you are talking about are in the intake itself. They are called bellows. The hood helps to keep rain, snow, sleet and hail out of the air system. The filter is able to keep out dubris, and some water. But not all of it. How do you think that you get a water slug in the engine when you hit a puddle or something. It goes right up through the filter and...well you know what happens. KEEP THEM IN. There is no benefit to taking them out. Only setting yourself up for failure. Dont do it
    LS1 Noob
    Fredericksburg, VA
    2000 WS6
    A K&N type filter that's properly oiled will keep out any minor amount of water that may get to the intake through the hood vents. You need a really good gulp of water to hydro lock an engine.
    I had a GTP that I installed a water injection kit on years ago to combat a modified supercharger (helps keep temps down). The water jets were installed between the TB and SC and sprayed water every time I hit anything over 3.5lbs of boost. I had the kit on the car for over 110K miles. I sold the car with 190K miles on her and the SC and cylinders were very clean. A little bit of ocassional water is not going to hurt anything.
    2000 WS6 A4
    Quote Originally Posted by nytmare View Post
    You are talking about an atomized mist of water. The last time I was on the interstate when it was raining like hell, the massive waves of water coming off the semi's was not a fine mist, nor was it a small amount.
    Just my .02, But if you are going to gain nothing, why risk your engine...
    1999 Trans Am 5.7L
    Quote Originally Posted by Thorazine Shuffle View Post
    Ditto
    Aug 2006
    West, Central, Florida
    2000 Pontiac Formula
    Werd
    LS1 Noob
    Fredericksburg, VA
    2000 WS6
    Granted... I'm not an engineer and can't provide any test data. But I've had the baffles out of my hood for a couple years and have not had a problem. The car's a DD and I travel 60 miles round trip everyday on I95 in all kinds of traffic. If it was going to be a problem, it would have by now.
    For the record, I have a Volant intake with two cone K&Ns. They're cleaned and oiled on a regular basis. The additional air has made a difference in the way the throttle responds at speed.
  1. Wanted: Ls6 Intake, 40+lb Injectors, and 2 manual 3" cutouts
    By ChevyLS1 in forum Parts Wanted / Trade
    Last Post: 03-18-2012, 03:06 PM
  2. Tech help: cutouts, ls6 intake, ram air
    By 99Trans_Am in forum External Engine
    Last Post: 02-22-2008, 01:26 PM
  3. Cutouts open/cutouts closed
    By Mr. Luos in forum Multimedia Section
    Last Post: 03-31-2007, 03:07 PM
  4. Replies: 1
    Last Post: 11-25-2006, 11:47 AM
