Results 1 to 1 of 1
Thread: McLeod Master Cylinder
01-23-2007, 10:07 AM #1
Finished the drill mod and am assembling the system again. Would anyone think it is a mistake to use a stainless 1/8" cotter pin instead of the roll pin used to secure the line to the master cylinder. It should be close to the same diameter. It would be nice to reach down there and snatch out the cotter to remove the line instead of removing the heatshield that is behind my headers to remove the whole unit. Of course, if it leaks, I'll have to remove everything to fix it.-Cotter pin worked fine. Holds pressure. Also, I found an easy way to install the clip which holds the shaft to the pin on the pedal. Slide the clip over a small open end wrench which will spread it out and allow clearance for the pin. You can now easily put the clip in place and pull the wrench straight down.
McLeod master cylinder
By AirMarcus in forum Manual TransmissionReplies: 0Last Post: 01-23-2007, 06:33 AM -
FS: McLeod Clutch Master Cylinder "NEW"
By CSULALS1 in forum Parts For Sale / TradeReplies: 2Last Post: 07-26-2006, 04:01 PM -
By T/Aboo in forum Manual TransmissionReplies: 2Last Post: 07-19-2006, 01:00 PM -
McLeod Adj Master
By Wikked00Hawk516 in forum Parts Wanted / TradeReplies: 1Last Post: 03-15-2006, 07:01 AM -
Mcleod Master Cylinder
By noblesramair in forum Manual TransmissionReplies: 8Last Post: 11-02-2005, 08:24 AM
