    SDB
    Guest
    Heavily modded 2000 Camaro for sale...$25,000 O.B.O.
    2000 Camaro Z-28, approximately 45,000 miles on car (20,000 miles on shortblock)
    Monterrey Maroon with Saddle leather
    All options except T-tops and traction control
    MTI 382 stroker motor with Lunati rotating assembly
    Speed Inc SS3 camshaft .611/.619 242/250 114 lobe
    LS2 timing chain
    Lingenfelter ported and shimmed oil pump
    42 lb. SVO fuel injectors
    NGK TR-6 spark plugs gapped at .038
    Taylor Thundervolt spark plug wires
    Walboro in-tank GS340M fuel pump
    Hotwire kit for fuel pump
    Kenne Bell Boost-A-Pump
    Full Throttle Speed Timing Tuner
    ASP underdrive pulley
    Turn One aluminum water pump pulley
    AFR 225 heads, Platinum PRC Spring upgrade, hand finished by LPE
    ARP head bolts
    Stage 8 locking header bolts
    FAST 90 mm intake manifold
    Nick Williams 90mm Throttlebody
    BMR tb bypass kit
    Descreened MAF
    TSP lid with K&N filter
    free ram air mod
    Kooks 1 7/8" stepped to 2" stainless race headers with 3 ½" welded collectors
    Kooks 3" aluminized Y pipe with 3 ½" inlet/outlet
    Stainless Works 3 ½" stainless cat back exhaust
    SLP fan control switch
    Rossler 4L60E transmission with deep GM Truck style pan
    Royal Purple synthetic ATF for transmission
    Torque Management Delete
    Yank Pro Thruster 4000 stall torque converter
    10 bolt rear with 3.42 gears, Summit preload support cover, stud kit, synthetic fluid
    ARP wheel studs (rear)
    Edelbrock Torque Arm w/ poly mount
    Hotchkis front hollow sway bar
    Hotchkis rear hollow sway bar
    Hotchkis welded in sub frame connectors
    BMR lower control arm rubber/poly
    BMR adjustable panhard rod bar
    HAL QAI-R front shocks and springs
    HAL QA1 rear shocks with DMS lowering springs
    BMR bolt in control arm relocation brackets
    Prothane polyurethane motor mounts
    Bendix front and rear brakes with ceramic pads (new)
    Earls Hyperfirm Stainless Steel brake lines
    Ford HD brake fluid
    Hurst line lock kit with pre-bent lines
    Boyd Blaster wheels, 17 X 9.5 front 17 X 11 rear
    Sumitimo 275-40-17 front, MT ET Street Radials 275-40-17 rear
    Stull Billet Grill
    Window Tint
    Secondary alarm system
    Optima “Red Top” group 75 battery
    VIN acid etched in all glass
    NX GM MAF nitrous kit, remote bottle opener, thermostatically controlled automatic bottle heater,
    purge kit, nitrous pressure gauge, TPAS switch, three-button rocker panel control, blow down tube
    (Full GEN-X-2 kit). Small FP gauge mounted on fuel rail. Custom billet aluminum bottle brackets
    from Aerospace Engineering.
    Custom computer tuning at EPP
    *heads, cam, intake, TB, complete exhaust, tuning, brakes, water pump, etc. have less than 500
    miles on them.
    Car is freshly detailed in and out, looks great, perfect shape, looks like a 15,000 mile car. No disappointments, all professionally done.
    No trades, just wanting to sell out right (unless you happen to have a new C6 Zo6 black/loaded, thats what I want)
    -$25,000.00 O.B.O.
    Scott Bojrab 260-418-5889
    [email protected]
    SDB
    Guest
    bump to the top
    SDB
    Guest
    pics coming tomorrow, going to track 10-21-05
    SDB
    Guest
    have pics, if interested, send me an email to [email protected]
    SDB
    Guest
    bump ttt
  1. FS 2000 Camaro SS, modded 30k miles on new motor.
    By delusion in forum Vehicles For Sale / Trade
    Last Post: 07-06-2009, 12:03 PM
  2. 98 Trans-Am -- Heavily Modded Race Car
    By MastaAce98 in forum Vehicles For Sale / Trade
    Last Post: 11-27-2008, 09:45 PM
  3. X-posting, Lambo vs heavily modded SS
    Last Post: 04-12-2006, 06:32 AM
  4. wtb heavily modded z06/WS6 in southeast
    By showle02 in forum Vehicles For Sale / Trade
    Last Post: 03-28-2006, 05:14 PM
