Thread: 95 4.3 Blazer DD need help!
01-19-2007, 05:10 PM #1Junior Member
- Jan 2007
- Cville,GA
Silver and Black- 2002 Z-28 Camaro
i have a 95 4.3 vortec v6 blazer driver gotta keep the miles off the maro...vechile sat for bout a year before i bought it its got 187000 miles on it and it ran great when i first had it my sister just got back from a trip to savannah,ga which put bout 500 miles on it and had no problems day after trip it starts running shitty sounding like the catalytic converter was shot cuz there was noise coming from the area and it just started smelling like sh*t. then it wouldnt run we replaced the coil and it starts now but still running bad. you can mash the gas and the rpms will jump and sputter from 900-1100 and thats bout all ya get...was thinkin bout replace the spark plug wires but i dunno im at a loss of what to do anybody out there with any ideas id appreciate it
01-19-2007, 06:26 PM #2Junior Member
- Jan 2007
- Glendale az
Are you throwing a code? It sounds like a cat, but if ur throwing a code I'd look at the egr. Could also be a fuel problem. If you have the tools, I'd say vaccume test your egr, check the temp on your cat, and test your fuel pressure.
It'll probably end up being the cat, but it would suck to buy a cat and have an exhaust shop put it on(or u put it on urself) and have it be something else.
01-19-2007, 06:39 PM #3Junior Member
- Jan 2007
- Cville,GA
well i was gonna just cut the damn cat off and weld a piece of exhaust piping in its place cuz theirs no emissons law for the area i live in. but a cat wouldnt cause it to run like that would it? guess ill try checkin the egr
01-19-2007, 06:41 PM #4Junior Member
- Jan 2007
- Glendale az
an extremely clogged cat will make the motor run like shit... but won't throw a code. An egr will also make the car run like shit, but will throw a code. So is your check engine light on?
01-19-2007, 11:12 PM #5Junior Member
- Jan 2007
- Cville,GA
yes the check engine light is on it came on day or so later after the motor started running bad. would the egr make it just run bad all of a sudden? im going to check the cat tomorrow seeing as how their is noise coming from around the area where the cat is..buddy of mine totally denys there being any possibility its the cat but im tending to think it is
01-20-2007, 12:05 PM #6
Yep egr would do it, had it happen on my Full size Jimmy, quick stop from speed, knocked some carbon loose and stuck the valve open. I'd dump the cats too happened on dads 92 suburban, wa that way from the factory.
01-21-2007, 01:10 AM #7
I've had a couple of 4.3's and still have a truck that has it. Piece of crap IMO but some people rave about them.
Our 94 blazer had a problem with the EGR getting carbon in it. I took it off more than once and cleaned it. Easy to do and if memory serves me correctly there were two part numbers for that EGR and the one I needed was the expensive one so I would clean the old one when it needed it. Piece of cake to pull off and clean.
I've also had ignition issues with my truck. Have you had the distributor changed out lately? The distributor base is plastic and extremely easy to crack when putting the cap back on. Ask me how I know.
Another issue I've had is moisture getting under the wire on the coil. Seems my set of wires just don't seal tight to the coil so I loaded it up with dielectric grease and fixed that.
I would really want to see what code you're getting. Could be anything from misfire codes to EGR pintle position to an O2 code. Pull that code and post back up what it is and maybe someone can put you on the right track.
Being an OBD1 vehicle you can jump the pins with a paper clip and pull the codes yourself by counting the flashes the check engine light makes. I would have to look up the pins you jump because I don't know them right off hand. I *think* it's the upper 2 on the right of the connector but I would have to look it up. The light will flash and pause and flash again to give you the two digit code. An example is when it begins the diagnostic it flashes 12 which would be flash (pause) flash flash ( pause). It will cycle each code 3 times and finish with 12 again. Hope this helps and post back up with the code(s).
01-21-2007, 01:33 AM #8Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
Yes, the EGR on a 4.3 carbons up in no time, easy pull, easy clean.
There was also an issue regarding the connector that goes to the coil. Firsthand I've experienced the strangest symptoms, replaced the coil to have it run OK then fizz out shortly thereafter. GM has a TSB out on it but in essence you just replace the connector.
01-21-2007, 05:57 PM #9Junior Member
- Jan 2007
- Glendale az
01-22-2007, 12:11 AM #10Junior Member
- Jan 2007
- Cville,GA
well it turned out to be the egr after all...not the easiest thing to pull out i actually ended up disconnecting the radiator hose from the thermostat cuz it was in the way and the bracket the throttle cable runs through but once i undid the 2 bolts it was just and easy clean up. changed the pcv and ica valves while i was at it cuz they were both pretty dirty and worn and aint bout 3-5 bucks a pop. SES light is off...probaly cuz i disconnected the battery when i changed out the coil but shes back running great even with 187000 miles thanks everybody for the help.
01-22-2007, 09:05 PM #11
Glad you got it. I hope you remember how to do it because you'll be back under there cleaning it again in the near future.
Welcome to the world of the 4.3
Did you look and see if you have the infamous intake leak down the front of the motor? I've had 2 4.3's and both had the lower intake gasket leak. I just pulled the intake on my 97 and replaced the gasket this summer. Now that was a fun job.
01-23-2007, 10:46 PM #12Junior Member
- Jan 2007
- Cville,GA
nope didnt see if there was a leak but the right valve color leaks oil the same as my buddys 95 s10 did nothin major its just oiled up while the other is clean but i looked at getting and after market edelbrock intake would that eliminate the egr? they offer them with egr and without egr?
For Sale: 1989 Chevrolet Blazer Blazer Full Size
By bills98ta in forum Vehicles For Sale / TradeReplies: 13Last Post: 08-25-2010, 07:27 AM -
Help with my dad's 04 Blazer
By Sweet Chops in forum Almost Anything GoesReplies: 15Last Post: 11-27-2009, 11:58 AM -
S10 blazer
By Toes in forum GM TrucksReplies: 6Last Post: 03-02-2009, 04:23 PM -
71 Blazer $4K
By TonyJ in forum Rocky Mountain MembersReplies: 0Last Post: 03-27-2006, 05:14 AM
