Results 1 to 17 of 17
Thread: Post up your FI fuel systems
08-07-2005, 06:37 AM #1
Like the title says. My fuel pressure drops at WOT from 60lbs to 45lbs and It's scarring the crap outta me so I want to see how to remedy this.
Mine:
60#morton Injectors
Walbro 255l intank pump
KB boost-a-pump
What else to i need? I am runnin about 13 to 14lbs of boost.
TIA
Mike
08-07-2005, 06:17 PM #2
- Aug 1999
- Arizona
I hope I don't have the same problem. I am waiting for Racetronix's Rail Mounted Fuel Pressure Regulator.
http://www.racetronix.com/Racetronix-FLS1-Reg.html
Your regulator is most likely causing that drop. How is your AFR?
08-08-2005, 04:10 PM #3
I never drop below 14 psi or much above that either.
Running 12 lbs of boost.
I would be afraid of getting a lean condition with loss of pressure. I would be careful with WOT until you remedy the fuel pressure situation.Last edited by cham; 08-08-2005 at 04:14 PM.
08-09-2005, 04:01 AM #4
My AFR is right around11.5
08-09-2005, 04:03 AM #5
I was thinking about maybe putting in another fuel pump in the tank and a pressure regulator. I will check that out.
08-13-2005, 01:52 PM #6ForcedEnforcerTAGuest
You might want to pull your pump out again and check the rubber fuel hose going to it. I had similar problems with my fuel pressure on my walbro 255 come to notice the hose was tearing in half and exploding. If you can get a hold of some real high pressure fuel hose swap it out. Some reason the hose they gave me with the kit lasted two weeks. Threw in a goodyear hose just to give me some time till I got some high pressure hose and that only last 2 weeks. At idle I would have 70psi at the rails but on the gas I would lose pressure.
08-13-2005, 09:46 PM #7
I will tell you guys what I have in the making.
60 #'s Motron
2 255's walbro intanks
2 Aeroquip Socketless Hose Ends -6 AER-FBM1512
4 Aeroquip Socketless Hose Ends -8 AER-FBM1513
1 Earl's Performance Bulkhead Adapter Fittings EAR-983308ERL
1 Earl's Performance Bulkhead Nuts EAR-992408ERL
1 MagnaFlow Y Fittings MRF-MP-6286
1 Russell Aluminum Fuel Line Adapters (For the return from fuel rail.)
20 ft Summit Fuel Line Combination Kits -8 SUM-PUMPKIT3 (This might change if my stainless tubing comes in and I custom bend it to look like stock)
4 ft of Summit Fuel Line -6 (For the intank Y block setup. You dont want to go cheap here. The cheap ass hoses they send with the pumps wont hold.)
Speed INC fuel rails
Speed Inc fuel filter
Speed INC fuel pressure reg with boost reference
Hot wire fuel pump kit http://cgi.ebay.com/ebaymotors/1999-...spagenameZWDVW
Blocked off the T and removed the OEM fuel filter. This way you can use the old feed line as a return. This is not a cheap setup. This is all in all about $600 to $700. Not including the price of the injectors. But this would support 850 rwhp no prob. IMHO
And here is what inspired me to do this. http://www.cofba.org/users/smokinhawk/fuel.htmLast edited by JMBLOWNWS6; 08-13-2005 at 09:57 PM.
08-15-2005, 01:41 PM #8
That sounds like a great setup. I want some pics when you get done.
08-15-2005, 04:27 PM #9
Originally Posted by finishline
Sure. I will have pics in two weeks. I just ordered everything. I will definitaly post how I did everything.
08-16-2005, 03:40 AM #10
awesome thanks for the great post
08-29-2005, 11:22 AM #11
- Earth
pewter- 2000 C5
RC Engineering 75# High Impedance Fuel Injectors
Racetronic C5 High Flow Intank Fuel Pump
A&A Corvette Modified Kenny Bell Boost-A-Pump
-8an Braided Stainless Steel Fuel Send Hose
-8an Braided Stainless Steel Fuel Crossover Hose
-6an Braided Stainless Steel Fuel Return Hose
CAS Billet Fuel Pressure Regulator
Magna Flow High Flow Inline Fuel Filter
Nasty Performance Custom LS2 Billet Fuel Rails
Pure Choice Performance -6an Fuel Rail Adapters For Sending Unit
New setup:
Old setup:
Keith
08-30-2005, 08:36 PM #12
09-04-2005, 01:59 AM #13
True but it is nice to have more than enough fuel pressure. Just a peace of mind thing.
09-04-2005, 02:01 AM #14
Originally Posted by kromberg
09-04-2005, 02:07 AM #15DisCreteGuest
I have EFI SAS system
Electronic Fuel Injection Slow Ass Stock system.
09-06-2005, 07:12 AM #16
- Earth
pewter- 2000 C5
Keith
09-06-2005, 02:47 PM #17
Nice job hiding the coils and plug wires. I cant find any of them. Where did you stick the 8 coils in that packed engine bay and why cant I see your plug wires?
Multiple Fuel Systems - Multifuel Upgrades
By Ed Blown Vert in forum Almost Anything GoesReplies: 2Last Post: 08-27-2009, 07:55 PM -
Corvette Fuel Systems - Fueling The Fire
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-21-2009, 08:50 PM -
Aeromotive Fuel Systems Insight - CHP Insider
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 04-14-2009, 11:50 AM -
Stand Alone Fuel Systems
By Whiteboycntdnce in forum NitrousReplies: 1Last Post: 10-22-2008, 10:42 AM -
Post Your Sound Systems
By 2000silverbullet in forum Stereo and ElectronicsReplies: 142Last Post: 04-27-2008, 08:30 PM
