Results 1 to 14 of 14
Thread: 150 wet/dry kit on a hawk
01-15-2007, 06:20 PM #1
- Jan 2007
- Arlington
Black- 2002 Firehawk Trans Am
I just wanted to know if it would be okay to put a nitrous kit on a pretty much stock hawk. I have minor bolt ons, but performance places told me that 150 shot of wet would be fine, that i wouldnt have any problems. I dont know if they were just sayin that to make me buy it, or what. I always wanted a 80 shot of dry, but many people told me it wouldnt be worth it. What do you guys think?
01-15-2007, 06:39 PM #2
- Cape Coral, FL
Mystic Teal- 99 Trans Am & 01 CBR 929
100 dry, 150 wet.. either would be just fine on a stock engine
01-15-2007, 07:55 PM #3
- Jan 2006
- Laffyette LA
1993 chevy pickup DD- 1999 camaro ss
yep just make sure you read up and install it correctly and your a-ok with what he said above
01-16-2007, 04:28 AM #4
wet is better from a tuning and upgrading aspect.
with a dry, you have to rely on the MAF and injectors to supply the additional fuel. if the nozzle isn't placed right, the MAF won't read correctly and not provide the needed fuel. also, if you ever want to go above 125ish, then you will need to upgrade the fuel pump and injectors.
with a wet kit, it provides the added fuel through the nozzle via the fuel rail. no need for larger injectors this way. you can tune it by changing the jets to get the proper a/f ratio. i've been to 200 on the stock pump.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
01-18-2007, 12:17 AM #5
- Jan 2007
- mississippi
red- 2000 trans am
you guys are crazy I would at least program the car first esp with a dry kit. timing is everything
01-18-2007, 04:26 AM #6
and why are we 'crazy' exactly?
01-18-2007, 12:17 PM #7
- Jan 2007
- mississippi
red- 2000 trans am
I wouldn't recommend spraying a car that is not programed... and by the way the preditor is the way to go!
01-18-2007, 05:47 PM #8
um ok. guess i should've never sprayed my car with stock programming for the last year or so.
and predator isn't the only way to go. there are better ways.
01-18-2007, 11:15 PM #9
- Jan 2007
- mississippi
red- 2000 trans am
ok sounds like you know it all ab stock cars programmers and nitrous...
01-19-2007, 11:58 AM #10
well, i think i know my fair share.
just a couple of things i've done personally:
nine nozzle test i did
http://www.ls1.com/forums/showthread.php?t=22348
small solenoid vs larger solenoid
http://www.centralfloridastreetcars....eshootout.html
dry vs wet test
http://www.ls1.com/forums/showthread.php?t=27619
i did some dyno and track testing for vinci high performance and their tuner
http://www.stealthram.com/vhptuner.htm
currently using hptuners
you make these statements without any reasoning behind them. i'm sure you have some great qualifications, but we just don't know what they are. oh and my greatest feat, IMO, is when i took my black car completely stock, no modifications whatsoever, and put 150+ nitrous on it and went 11.97 @ 117. all stock down to the tires. mull over my webpage just on my black car. http://www.stealthram.com/2000pontiacformula.html
01-19-2007, 04:31 PM #11
mrr23 is very knowledgeable. He has helped me out on many occasions in my short period of time having my ls1, wether he knows it or not. Its just hard not to notice your contribution to this site, 4 posts or so, and think that you know what you are talking about. From what I understand both setups are good, it just depends on what you want. I personally have a wet set up and have had no problems with it yet. A problem with the wet set up is the potential for the selinoids to stick open and possibly backfire. The dry set up has to rely on the MAF to compensate for the nitrous.
01-19-2007, 07:27 PM #12
- Jan 2007
- RICHLAND MS
RED- 1999 COUPE
I Have A 150 Wet Shot On My 99 Corvette With Auto Trans An Its Runs Fine On 93 Octane I Say U Be Fine /
01-19-2007, 11:18 PM #13
- Jan 2007
- mississippi
red- 2000 trans am
I've had ab 5 ls1s and only replaced 1 motor the only mod at the time was a 100 dry shot. any way I have a prob with wheel hops any sugg? everything stock back there
01-20-2007, 10:19 AM #14
wheel hop can be caused by a couple of things. shocks is one place to start. getting aftermarket trailing arms is another. trailing arm relocation brackets is a third.
With my 02 hawk..
By Ws6islife in forum External EngineReplies: 6Last Post: 09-28-2011, 07:31 PM -
mow hawk
By qwkgto in forum GTOReplies: 2Last Post: 01-09-2009, 05:50 AM -
hawk 1/4
By hawk18 in forum Drag RacingReplies: 14Last Post: 06-02-2008, 03:32 PM -
WTT a LS1 Hawk for a LT1 WS6 or Hawk clip
By 1badchicken in forum Western MembersReplies: 0Last Post: 10-18-2007, 05:37 PM -
Someone please buy my old 94 hawk
By 1badchicken in forum Cowhands, Local Parts and Fish BaitReplies: 5Last Post: 08-23-2007, 07:56 AM
