Results 1 to 2 of 2
Thread: can't get my lower a-arm off!
01-15-2007, 02:59 PM #1
how do i get the 2 bolts out of the lower a-arm front bolt hits the steering rack boot, the back bolt just wont budge. is the back threaded in the k-member or something the nut is off and wont push up thru. should i do something diffrent please tell me what works.
01-18-2007, 05:57 PM #2
unbolt the tie rod from the spindle to move it out of the way.
the bolt will come out. take the arm and push it inward as far as it will go. then pull the bolt out.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
Wtb 98-02 ram air lower air box
By mv507 in forum Western MembersReplies: 0Last Post: 01-04-2011, 06:10 AM -
Wanted: lower (ws6/ram air) air box
By Blackbird WS6 in forum Parts Wanted / TradeReplies: 39Last Post: 11-24-2010, 02:17 AM -
Lower Air box
By 96z28 in forum General HelpReplies: 2Last Post: 12-10-2007, 11:09 AM -
lower tire press. higher ET, higher press lower ET???
By greatwhiteZ28 in forum Drag RacingReplies: 1Last Post: 10-20-2007, 05:57 PM
