Results 1 to 20 of 29
    doylestown, Pa
    SILVER
    2004 CTS-V
    Does a 98 PCM work with a 99 Engine!
    When I bought my car, ( 98 Z28 ) it came with an engine out of a 1999 Z28.
    Heres what I don't understand. The (98)PCM is set up for 28lb. injectors, but the (99) engine comes with 26lb. injectors. How is this making my engine run? Theres no check engine on. Would they have had to tune it? What difference does it make with them being 28lb. and 26lb. ? How can I tell the difference between?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    nope they are different.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    that small of an amount on the injectors wouldn't matter, or even really be to noticable.
    doylestown, Pa
    SILVER
    2004 CTS-V
    What is different?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    What is different?
    from what i have read, in 98 the pcm can go either auto or m6, 99- 02 has to have one or the other. hence m6 pcm with m6 trans.
    but i also read recently that there is an adaptor for that. someone will clear this up i'm sure.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Why then, did GM change the injector size?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    probably because it was cheaper and that little bit didn't effect much.
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    The 1998 ECM will only work on a 1998 Engine Harness, it has nothing to do with the engine. The previous owner possibly swapped the injectors from the 1998 car to the 1999 engine.
    Also a 1998 PCM will work on a manual or auto, it is in the prgram and can be flashed to either. Same thing with a 1999-2002 PCM ... you can use them on either auto or manual, it is just a simple reflash for the proper trans.
    Basically, don't worry about.
    George P. Lara
    Mine 2001 Camaro SS #0391: FQuick Garage
    Mrs.'s 2002 Camaro SS #7072: FQuick Garage
    EU
    I´m gonna do tune, I need engine control only .
    Does it matter which car computer comes, if it´s gonna be reprogrammed? Supposing that, harness is fixt for given sensors.
    Do all ls1 ecm:s have same internals, or is there more differences than programs?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Well, from what I have heard, the 98 PCM is the worst one!
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    just hardest to tune.
    doylestown, Pa
    SILVER
    2004 CTS-V
    What do you mean by that? What will be the difference in tuning my 98 PCM compared to a 99> PCM?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    tuner say it is harder to tune the 98's, and some charge more.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Is it posible to convert my car to a 99 PCM? What would it take?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i would guess just wiring, check the tech section here i think someone has done it but i can't remember.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Thanks man! You've been a big help!
    Car RamRod 98Camarod's Avatar
    Feb 2006
    Goose Creek, SC/ NWS
    Green
    1998
    If I had to guess why the injectors are slightly larger it is probably due to the slightly larger cam in the 98.
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    I would not go to a tuner that says that. Tuning a 1998 ECM is no different then a 1999+. Many of the fastest cars were running OEM 1998 computers back in the day. I do not charge extra for a 1998, because they are not harder to tune. Granted, there are some tables that are not available to 1998 as there are to 1999+, but you can still tune the idle, part throttle and WOT just that same and with great results.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Allright. The next step is to find someone good to tune my car on the EastCoast. Bolt-ons exc.exc. Anybody know of a good tuner near Philadelphia?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by 12secSS View Post
    Finally someone who knows what they're talking about, from experience, regarding the 98 PCM. Thanks for the input.
  1. Major Engine Work... Impressions (Finally)
    By Naaman in forum Parts Review
    Last Post: 03-18-2016, 04:28 PM
  2. crazy day at work with an engine
    By BamBam87 in forum External Engine
    Last Post: 06-15-2009, 09:56 AM
  3. 07 zo6 at my work, blown engine
    By blue02Z in forum Almost Anything Goes
    Last Post: 02-26-2009, 07:50 AM
  4. would VHT engine enamel clear work good on painted enigne bay?
    By greatwhiteZ28 in forum Appearance Section
    Last Post: 09-25-2007, 07:16 PM
