    Junior Member swimster144's Avatar
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    Hoping Engine isn't Blown...
    So I was out driving tonight, and playin' around. I mis-shifted and I think the engine RPM went pretty high, but I'm not sure how high since it all happened so fast. But, the weird thing is, it jerked my car rapidly really bad and killed the engine. Went to start the engine back up but no go. Pulled it over to a safe spot and tried again, no go...finally it started up, but barely, and idled REALLY roughly, sounding almost like it was misfiring or running out of gas or something. It was also shaking the car kinda bad as well as the shifter. Then it would die after a few seconds...
    So, I've mis-shifted before and accidentally sent the RPM's up, but it never hurt anything nor did it kill my engine. I have no idea what could be wrong. I'll have it towed to a shop tomorrow, but does anyone have any idea what it MIGHT be??? It is a 1999 Camaro Z28 (LS1) with a 6 speed manual.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    check the plugs, sounds weird but worth a try.
    any noises?
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    I checked the plugs and the wires, they all seemed normal from just a visual check. No weird sounds or anything or the sort aside from it just idling like shit and then dying.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    were you low on gas? or out?
    you should take the plugs out one at a time to check them.
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    well I had a little more than 1/4 tank left when it happened... I'll have it towed tomorrow to a shop and we'll see what they say. I've tried doing plugs before and they are a bitch to even get at, so I bagged it.
    I am wondering if my rev limiter kicked in and cut the fuel right as I put the clutch in and something happened to the fuel pump. That would explain why it jerked REALLY badly when I tried to let the clutch back out, being in gear with the engine basically off. Is that possible?
    a lil slap n pickle SSee ya's Avatar
    Jun 2006
    Scottsdale, AZ
    +1 to the fuel pump
    Mesquite, TX
    2001 Z28 M6
    Also might have bent or broke some pushrods. Stock rods are known to do this when hitting the rev limiter hard.
    I'm guessing bent pushrod (s).
    Retired Outlaw Sum Bitch
    Probably floated a valve. From there you could have busted a valve spring or a valve itself. If a busted off piece got into the cylinder...you bent a push rod or have a hole in a piston. No biggie...part of hot rodding man....
    This is my signature. It is mine. Nobody else has one like it.
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    thx for all the input guys, we'll see what happens, i'll let you all know.
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    Ok, so basically, its either a blown cylinder head on the driver side of the engine, or just a blown engine... I'm going to be selling the car anyways, but what do you guys think is best? Should I first drop a brand new LS1 in it, and then sell it? Or should i sell it as is, for around $4,000 - $5000?
    O and BTW, the car (chassis and all) only has 66,000 miles on it, and it has an upgraded sound system in it with Pioneer Deck, and Polk speakers, and would also come with a few SLP performance parts (SLP MAF, SLP Airlid), straight pipe exhaust setup and K&N filter...
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    So basically I ended up putting a whole new LS1 into it cause I wasn't sure what was wrong the engine and I didn't want to risk replacing part of it to find out the bottom end was toast. So now the car is practically new condition and drives like its new. It's awesome...too bad I have to sell it cause I can't afford to keep it and I really need a 4X4 to get me around a little better in the snow for the time being. Check out the thread I am selling it on if any of you are interested. Thanks.
    http://www.ls1.com/forums/showthread.php?t=40261
  1. 07 zo6 at my work, blown engine
    By blue02Z in forum Almost Anything Goes
    Last Post: 02-26-2009, 07:50 AM
  2. engine blown?
    By adham in forum General Help
    Last Post: 04-14-2007, 11:59 AM
  3. blown engine, prices?
    By Brownboy2020 in forum Internal Engine
    Last Post: 03-10-2007, 04:46 PM
  4. very sweet blown engine
    By ss~zoso~ss in forum Almost Anything Goes
    Last Post: 08-12-2006, 06:13 AM
  5. engine blown 98 what to do?
    By purplcam in forum General Help
    Last Post: 10-30-2005, 10:14 AM
