Thread: LS7 Crank into a LS1/6 block
01-09-2007, 10:14 PM #1
- Apr 2006
- Cincinnati
Black- 03 Mustang BIW NMRA R/S 8
Did a search on this but found no info. Was wondering if the LS7 crank will fit a LS1/6 block. The main specs are the same according to the GMPP catalog. Coming from the Mustang world I'm a little spoiled by the cost and strength of the Cobra crank, hoping to luck out with the GM stuff too. I'm looking for a forged crank to build a 383.
01-12-2007, 07:15 AM #2
- Apr 2006
- MINNESOTA
BLUE- 2000 SS CAMARO
Just use an Eagle or the new Compstar crank. The ls7 crank has a longer snout (dry sump oil system I guess), and it has a 58x reluctor, which would require you to use a newer pcm.
01-12-2007, 09:15 AM #3
- Apr 2006
- Cincinnati
I've done machining before and personally don't like Eagle anything. I will look into the Compstar, which I believe is Callies? The price of the LS7 crank is what got my attention. May call Doc Meyer and see what he says.
01-12-2007, 10:37 AM #4
- Apr 2006
- MINNESOTA
If you are starting bare bones IE: no pcm or anything, then all you would have to do is machine the snout on the crank and buy a pcm that is setup for a 58x reluctor. You may be money ahead that way. I honestly couldn't tell you the price differnece. FWIW I went with a callies Dragoonslayer crank in my build.
01-12-2007, 11:06 AM #5
- Apr 2006
- Cincinnati
I thought maybe GM sold the 24X 12559353 wheel in the GMPP catalog to replace the 58X. How much longer is the snout do you know? The crank is less than $750 most of the places I have contacted.
01-12-2007, 12:40 PM #6
- Apr 2006
- MINNESOTA
I really don't know how much longer the snout is, but it is long enough to have to machine it. You can have the reluctors changed out. check Speedinc.com for a price on the compstar crank. I think it is like $805.
01-13-2007, 07:25 AM #7
- Dec 2006
- Nottingham, UK
Also, you may have to add a lot of tungstan to the ls7 crank? The Compstar sounds good and callies may rough balance it for you. $800 sounds like a really good price to me.
01-14-2007, 01:09 PM #8
- Sep 2005
- San Diego
Also the ls7 crank is very heavy.
Chevy Small-Block, Big-Block & Transmission Buildi
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 11-20-2009, 01:50 PM -
6.0l block and 4.8l crank
By 99transamC/FIA in forum Parts Wanted / TradeReplies: 0Last Post: 08-08-2009, 09:44 AM -
#241 LS1 heads, 5.3 block, LS1 crank
By jjz28 in forum Parts For Sale / TradeReplies: 0Last Post: 01-24-2007, 12:09 PM -
Older 305 engine block with crank, rods, piston, cam
By 02gixxersix in forum Parts For Sale / TradeReplies: 2Last Post: 09-24-2006, 03:52 PM -
ported ls6 heads ls6 block crank and rods.
By roadrash9r in forum Parts For Sale / TradeReplies: 7Last Post: 09-24-2005, 01:29 PM
