Thread: Broken exhaust manifold bolt
01-07-2007, 10:38 PM #1
Damit!
Every thing was going so well all the bolts were coming out no problem. I was kinda just skipping around bolt to bolt loosing each one alittle at a time. I went an put the socet on the 1st bolt on the drivers side and it was already loose. Well that was odd cause I did't remeber even touching that one yet. The damn thing had broken off some how and I have no idea how cause I never even toched it. Whats the easiest way to fix this? There is nothing sticking out to grab ahold of it pretty much flush with the head. What are the chances it won't leak? I'm thinking of just putting the header on and hoping for the best. Every thing else went so smoth the pass side came off no problem and the new header went right in.
Thanks
Jon
01-08-2007, 08:06 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Buddy of mine cross-threaded the same bolt installing his and couldn't tighten it all the way. His didn't leak. He later broke it off trying to get it out to replace it, then drill it and try to get it out- unfortunately he hit dexcool. My advice is have a shop get it out. At least it's #1, could be worse.
01-08-2007, 08:41 AM #3
Blow-by without a bolt?
I installed Percy's High Performance gasket, Aluminum on my install. They will probably seal for you as they compress when torque is applied unlike a lot of the others. Over time I believe any gasket will blow-by without a bolt. But.....if hard pressed would go with the latter and check for burn through from time to time. May never leak but a pain to change as you know so if you have the time get a machinist drill/tap and remove bolt. They have the proper drill bit/tap and because it is #1 have it out PDQ.
2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
337rwhp/348rwtq
12-05-2008, 06:30 PM #4Junior Member
- May 2007
- houston
black- 2001 ws6 trans am ramair
how much will that be to fix im haveing the same thing whit my ws6 and the guy at the shop say it was like that but i know he did it
12-06-2008, 01:29 AM #5
12-06-2008, 07:54 AM #6
Personally, I would do it myself. Take the head of, buy a left handed drill bit that is quite smaller than the bolt diameter. Make a nice starter punch hole in the middle of the bolt so your not sliding all over. If your really lucky, the left handed drill bit will take it out when drilling. Probably not though, its worth a try. Then go buy some "easy outs". They work great. I have used them so many times with great results.
Pretty much what your ding ( and what the shop would do) is drill a hole in the broken bolt, then smack the easy out into the hole and use a wrench to turn it out. I dont see any other way of doing it.
There is the method of welding a nut to the bolt(not the head)... but that takes some skill, I have screwed up a Cat head trying to be a hero and doing that. Do what you feel comfortable with.
12-06-2008, 10:04 AM #7Junior Member
- May 2007
- houston
my car is at a shop and i wanted how much money to pay them for the work there tell me about 250.00 bucks to fix is that to much ???
12-06-2008, 12:39 PM #8
There is an old saying, If your gona play your gona pay. It realy depends on what it is worth to you to have them do it. Oh and I would talk to the shop owner and tell them something like I brought it to you to avoid this kinda of shit. if he doesn’t offer to cover the cost I would offer to split the cost with him since they broke it.
12-07-2008, 01:03 AM #9Junior Member
- May 2007
- houston
i did that he says my car was like that win i come in to the shop thats some b.s but now my cars is all in parts in hes shop and i dont know what to do but pay him to fix it ???
12-07-2008, 10:01 AM #10
12-07-2008, 10:25 AM #11
Pick up some Left handed drill bits, and extracter set and a angle drill. Start off slow and small and work your way up in drill bit size. Dont rush it and ensure your centerd on the bolt. If you get lucky it will back out with the drill bits. If not then you will need to use the extractor's. Also becareful not to break off the extrator, could make life horrible. Dont need to remove the head.
Tools = 60 bucks
labor = free
Case of beer = 13.00
Feeling of accomplishment priceless
12-07-2008, 01:23 PM #12
Broken Bolt
By johnfin in forum Firebird / WS6Replies: 15Last Post: 09-07-2012, 03:33 PM -
Help: Broken exhaust manifold bolt !!! Need help!!
By FirehawkM6 in forum External EngineReplies: 1Last Post: 04-21-2011, 10:11 PM -
Help: broken intake manifold bolt !!!!!!!!!!!!!!
By victor111262 in forum Internal EngineReplies: 26Last Post: 09-18-2010, 10:56 PM -
Broken Bolt
By bealschad in forum Internal EngineReplies: 4Last Post: 02-22-2007, 02:48 PM -
Broken Manifold bolt....driver's side
By sills1 in forum External EngineReplies: 12Last Post: 09-20-2006, 10:58 AM
