Thread: clutch prob
01-07-2007, 02:44 PM #1Junior Member
- Nov 2006
- ft collins
red- 01 ss
clutch prob
hey guys i have a quick question. iv been driving my car in a lot of snow so iv been pretty rough on the clutch its a spec stage 2+ and i got on to the highway and i started noticing that when i push my clutch in it takes about 3" to engage when before it was about a half an inch. any help would be nice.
01-07-2007, 03:38 PM #2My Neighbors Hate Me!!!
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
Quick question, have you upgraded your clutch master cylinder or changed it out since the clutch swap? Cause if not, it's probably about time... Another thing is that the stock clutch master cylinder is very restrictive, one method of overcoming this is the drill mod. I'm in the process of changing flywheel, clutch, and all clutch components, better believe i'm doing the drill mod.
01-08-2007, 01:42 PM #3
Clutch master cylinder
Mine started that and it took a new Clutch Master Cly to make it right. I lived with it for a few weeks and then it would stay down/come half up or any where in between. Finally stayed down and of course couldn't shift gears. Not saying that is your problem but sounds similar.
01-09-2007, 04:04 PM #4Junior Member
- Nov 2006
- ft collins
red- 01 ss
hey thanks for the info, it did end up being my master cyl. it has a bad leak in it. so i gotta save up money to get a new one. what one would you recomend.
PRC Ported Stage 2 Dart Casting, complete with PRC springs.
Camshaft
Chromemoly Pushrods
Modified LS6 oil pump
Rollmaster Double-roller non-heat-treated LS1/LS6 timing set.
Basic GM Heads & cam kit: head bolts,headgasket,timing cover gasket,front crankshaft seal.balancer bolt.
379 hp
01-09-2007, 04:39 PM #5
Gm P/N 12570277
I replaced mine with a GM P/N 12570277 for $154.99 (the part) from WS6
http://www.ws6project.com/user_stor/catalog/
I have read they don't have very good support but have never had to use them for that. I order parts and they are fast and exact. There might be cheaper sources out there so check around. I never knew mine was going bad until I got a new one..what a difference.2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
337rwhp/348rwtq
pcm prob i think
By jasonarthur in forum Computer & TuningReplies: 4Last Post: 04-09-2011, 06:00 PM -
installed clutch master cylinder today..fixed prob
By JehalinTA in forum Manual TransmissionReplies: 0Last Post: 06-25-2009, 02:01 PM -
Fixed my Sticking Clutch prob!
By The_Wretched in forum Manual TransmissionReplies: 4Last Post: 04-03-2008, 11:16 AM -
a/c prob help!!!!
By larryndog in forum General HelpReplies: 8Last Post: 07-25-2006, 12:17 AM -
01 clutch prob
By JattGunMan in forum Manual TransmissionReplies: 0Last Post: 06-07-2006, 03:06 PM
