    Member tav8ws6's Avatar
    New Jersey
    Sunset Orange Metallic-M6
    2002 Pontiac Trans Am WS6
    how to remove auto shift knob?
    ive asked this on the automatic transmission page without any luck so far, so does anyone here know how to remove an automatic shifter knob on a trans am?
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    On my camaro there was a metal clip shaped like a "U" that is pushed thru the leather from the back (radio side) and you have to pry it out and then just slip the knob off. I did it to install a billet knob.
    Senior Member
    Jacksonville, FL
    Yeah, it's the same - I have a Firebird handle on mine. It's easier to see/remove if you turn the key on and put the shifter in first.
    LIVONIA,MICHIGAN
    PEWTER
    Good point, I forgot that I did that too.
    New Jersey
    what did you use on the firebird handle to remove the clip? would needle nose plyers work?, flathead screwdriver?
    Senior Member
    Jacksonville, FL
    A small flat head screwriver to pry the clip out a little, then needle nose plyers for the rest of the way if needed.
    New Jersey
    ok, thanks, ill try it out tomorrow and ill get back to you on my progress
    New Jersey
    i got the clip out easy enough...launched out and bounced around...but now what? it seems stuck, do i just pull straight up, i dont think it can be screwed off
    New Jersey
    nevermind, i got it off, thanks guys
  1. Changing the Auto Shift knob
    By BANDITCAR in forum Appearance Section
    Last Post: 12-02-2010, 02:55 PM
  2. c6 auto shift knob in 2000 camaro
    By 00camaro16 in forum Appearance Section
    Last Post: 04-20-2010, 07:52 PM
  3. New Shift Knob
    By Eric1987 in forum Camaro / SS
    Last Post: 08-08-2008, 10:12 PM
  4. Shifters or Shift knob/handle for Auto tranny???
    By Mustang Killa in forum Automatic Transmission
    Last Post: 12-15-2007, 12:37 AM
  5. how to remove shift knob????
    By tav8ws6 in forum Automatic Transmission
    Last Post: 01-09-2007, 04:16 PM
