Thread: Automatic transmission
01-06-2007, 01:08 PM #1Junior Member
- Jan 2007
- Ohio
blue green- 1998 TA convertable
I have a 98 TA convertable with about 130,000 with the tranny rebuilt about 95,000. My question is whenever the weather gets cold the shift button won't depress until the car warms up. Any ideas what is wrong?
01-06-2007, 05:33 PM #2
Define cold, could be the cable lube is old and gets stiff, could be moisture that is freezing.
01-07-2007, 09:16 AM #3Junior Member
- Jan 2007
- Ohio
Cold is usually anything below 55 degrees.
01-07-2007, 09:19 AM #4King 0f n00bz
- Jan 2006
- Shepherd, Michigan
sounds like the a lube problem.
01-07-2007, 09:22 AM #5Junior Member
- Jan 2007
- Ohio
so how do I replace the cable lube?
01-22-2007, 02:28 PM #6
we're having the same problem over here:
http://www.ls1.com/forums/showthread.php?t=39785
In my case I can see that the cable is moving freely and I think it's the switch near the brake pedal but I'm really not positive. Any help would be appreciated.
01-22-2007, 02:36 PM #7
I forgot about the brake inter lock. the slonoid or switch could not be working properly. If you want to relube the cable, something like a spary in molly/lythuim lube should work. You ahve to remoce the cable from the shifter and tranny to do it right.
Automatic Transmission Question
By Redrokit8 in forum Firebird / WS6Replies: 5Last Post: 09-28-2011, 06:26 AM -
Help: Automatic transmission problem
By one_fast_z28 in forum Automatic TransmissionReplies: 2Last Post: 03-29-2011, 10:55 AM -
Question: SLP headers will not fit automatic transmission?
By b.lee in forum External EngineReplies: 18Last Post: 03-25-2009, 07:26 AM -
Automatic or Manual Transmission?
By nospeedracer88 in forum DrivetrainReplies: 16Last Post: 09-18-2008, 02:53 AM -
Automatic Transmission from a 2000 Z-28
By prietodogg in forum Parts For Sale / TradeReplies: 15Last Post: 05-22-2007, 02:14 PM
