Results 1 to 3 of 3
Thread: Royal Purple Differential grease
01-03-2007, 06:41 PM #1
anybody use it? If so, does it add or take away gear noise? Are there any draw backs to using the stuff?
01-04-2007, 10:15 AM #2
i put it in my car, no problems, the idea of it is to reduce drag from the thick gear oil in ther from the factory i did notice that the royal purple was slightly thinner and is supposed to lower temps
heres a test you can do , get a laser thermo reader and drive your car 10 mile and take the temp do this for 2 weeks every day and note the air temp as well , then change the fluid to royal and do the same test to see if the average temp is lower
i thougt about that after i put it in my rear end other wise i would have done the test
new fluid will not hurt the diff .. only help
01-04-2007, 02:07 PM #3
2010 Royal Purple Giveaway - Royal Shop Talk
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 06-10-2010, 03:33 AM -
Royal Purple
By JwMonE99 in forum Almost Anything GoesReplies: 11Last Post: 10-11-2008, 05:57 AM -
Royal Purple
By Mr. Luos in forum Almost Anything GoesReplies: 62Last Post: 08-01-2008, 10:48 AM -
By Jims455 in forum Firebird / WS6Replies: 1Last Post: 01-07-2007, 05:53 AM -
Royal Purple
By MavrickCJH in forum Internal EngineReplies: 12Last Post: 10-16-2006, 04:59 AM
