Thread: My baby is down
01-01-2007, 06:45 PM #1Junior Member
- Oct 2006
- Texas
Black- '94 Z28
My baby is down
My Z went down on me the other nite. I believe its the opti or coil. I just filled up w/sum push water and not 100 yrds or so down the road she quit on me. Started sputtering and then died. wouldn't crank back up and i even tried the next day and still didn't crank so..... I have a MSD opti on the and im gonna change the coil, plugs, and wires all at the same time. Imma also check hte timing chain and make sure it aint broke. I think i have alot of work ahead of me.
'94 Z-28 M6 K&N CAI, ORY, Unscreen MAF, TB Bypass, TB Air Foil, Flowmaster 80 series, Centerforce Clutch, 160 degree therm., 18X10.5 rear and 17X9.5 front Z06R wheels. soon to be taken to the track
01-01-2007, 09:23 PM #2
What do you mean push water?
A bad fuel pump or clogged fuel filter could also be the culprit. Changing the opti is a time-consuming process. I would look into the fuel pressure before tearing into the car.
01-01-2007, 09:26 PM #3Junior Member
- Oct 2006
- Texas
Black- '94 Z28
push water a.k.a. fuel/gas. I just put a fuel filter on there about 300miles ago. i had good presure at the manifold.
01-01-2007, 09:47 PM #4
All I can say is have fun with all the electrical stuff.
01-01-2007, 10:33 PM #5
When you replace everything put some washers behind the Coil/ICM bracket it will help keep the heat off the ICM.
01-01-2007, 11:36 PM #6A Tire Stores Best Friend
- Jan 2007
- Altus Oklahoma
Black- 1998 Trans Am
My 91 T/A did exactly the same thing after filling up a while back. It ended up being a fuel pump. It was hard to diagnose though because it would work sporadically. Good luck I feel your pain:-(
Boy at 13 has baby
By doberman 152 in forum Almost Anything GoesReplies: 31Last Post: 02-23-2009, 02:43 AM -
my 1st baby!
By bandit95 in forum Almost Anything GoesReplies: 17Last Post: 02-22-2009, 07:51 AM -
Baby cam
By c5z28 in forum Internal EngineReplies: 50Last Post: 02-21-2009, 09:05 AM -
my new little baby.
By crazy4jason28 in forum Almost Anything GoesReplies: 112Last Post: 01-08-2007, 07:38 PM
