Results 1 to 20 of 28
    What suspension mods do you have done?
    Just like the title says, list up your suspension/handling mods.
    Mine listed in order of install:
    BMR Strut Tower Brace
    BMR boxed weld in sub-frame connectors
    BMR boxed lower control arms
    BMR relocation brackets for the lower control arms
    BMR chromoly adjustable panhard bar
    BMR lowering springs
    KYB adjustable shocks(fixing to bite the dust)
    BMR drive shaft safety loop
    BMR upper panhard relocation kit
    Cross-drilled & slotted rotors
    BMR adjustable torque arm(awaiting install)
    Best mod listed above IMO is the sub-frame connectors and the worst is the KYBs. I am going to be replacing the rear KYBs for Koni SA ASAP.
    Pistol Pete '96 Z28SS's Avatar
    Cowboy Country Stillwater, OK
    Bright Rally Red
    1996 Camaro SS
    This is one area i havent hit very hard, but its my next in line.
    BMR Shock tower brace
    Bilstein SLP Valved shocks
    Slotted and Cross-drilled rotors
    Hawk HPS Pads
    Next on the list is subframes.
    --------- Chris - 1996 Camaro Z28SS #1524 ---------
    LT4 Cam Kit | Comp Lifters/PR's | Jet Hot LT's & ORY | Corsa RSC Exhaust | SLP Bilstiens | S-C/D Rotors | 1LE Elbow | !EGR/AIR
    madZ tune | 17x11 Chrome ZR-1's | Berger Panel | Fillins | BMR STB | Autometer A/F & Trans Temp | !Mouldings | Zaino
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    bmr shock tower brace
    bmr adjustable tq arm
    spohn adjustable trailing arms
    hotchkis panhard rod
    comp engineering adjustable rear shocks
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    BMR SFC
    BMR LCA
    BMR PHR
    Heater hose mod lowered my rear 1 full inch on both sides, cost $5
    BMR STB, took it off after a week, noticed nothing
    1LE FSB
    Bilstein HD shocks, BY FAR the best mod to date
    Brembo blanks & Hawk HPS pads
    Senior Member Carlos01SS's Avatar
    Aug 2003
    Cypress, CA.
    GC coilover springs 500#linear fronts 150#progressive rears riding on Koni DA's 4 full sweeps from firm fronts 1-1/2 sweeps from soft rears, Strano 35mm hollow front swaybar, LGMotorsports G2 dual rod-ended adj. PHR and SFC's with optional v-braces...I also have a chrome G2 STB, but I never put it on, same with the LCA brackets...
    The Black 2001 SS #5697
    T-tops, 6-spd/B&M ripper, ARH LT's/GMMG/CME, Volant, Koni DA's & GC coilovers, Strano frt & rear sways, G2(SFC's w/v-braces, STB, adj PHR), Wilwood 6-piston red calipers frnt brakes w/13" 2-pc rotors, RKSport(clear front & rear corners, c-f grill), chrome Z06 wheels
    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Here is what I have done:
    Koni SA's
    Hotchkis Lowering Springs
    Hotchkis Front and Rear Sway Bar
    Hotchkis Trailing Arms
    Hotchkis Strut bar
    Hotchkis Adjustable Pan Hard Bar
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    almost stock...
    with some minors add-ons/mods
    Eugenio_SS
    Quote Originally Posted by Eugenio_SS View Post
    almost stock...
    +2 I would not want to compile a list!
    Aug 2003
    Cypress, CA.
    almost stock...
    Hey man how you dooin???
    Long time no type!
    Hope all is well.
    almost stock...
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    I plan on adding a set of boxed BMR Subframe connectors (welded) in the future.
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    Member vikingramair's Avatar
    Sweden
    BLACK
    1999 Trans Am WS-6
    Here is my suspension mods
    BMR prog spring
    BMR shock tower brace
    Strano Swaybars f+r
    G2 adj phr/adj lca/adj up/low A-arms
    Koni Sa around
    UMI SFC
    Reloc batt to the trunk
    BMR chrome moly >
    Strut Bar
    SFC
    LCA
    Panhard Bar
    Torque Arm
    Sub Frame Connectors
    Spohn Rear Sway Bar
    DTS 12 Bolt,3.73
    QA1's soon
    Ohio
    97 Formula
    Factory WS6 springs.
    Bilstein HD shocks.
    32mm front swaybar.
    1LE front and rear swaybar mount bushings.
    Energy Suspensions poly endlinks front and rear.
    Hotchkis adjustable panhard bar.
    SLP strut tower brace.
    BMR boxed subframe connectors.
    Spohn poly rear control arms.
    WS6 wheels with Firestone Firehawk tires in 275/40/17.
    Plan on buying an aftermarket torque arm sometime this year.
    Member Fastcar's Avatar
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    Hotchkis polished strut tower bar
    SLP valved Bilstein shocks
    Energy Suspension polyurethane sway bar body mounts, end links and torque arm bushings
    UMI Performance bolt-in sub frame connectors, rear lower control arms,
    non-adjustable Panhard rod bar, and driveshaft safety loop bar (ties the sub frame connectors together underneath the driveshaft) (UMI front K member, upper & lower A arms with new ball joints soon)
    Brembo blank rotors
    Stainless steel brake hoses
    box n laddered LCAs
    UMI Torque arm [non adj]
    35mm Front sway bar
    Koni SA's w/ stock springs
    HotParts 2pt STB
    this spring:
    Tube SFCs
    adj panhard
    nittos
    Member camarolvr69's Avatar
    Woodbridge, VA
    1997 camaro z28
    how much do swaybars improve handling? is the change as noticeable as shocks and springs?
    OMG YES! it's less body twist and very attentive when you turn the wheel. a great combo is stiff shocks and a beefy sway bar
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    Here's mine:
    Suspension Technique swaybars (front & rear)
    Global West tubular weld in sub-frame connectors
    Hotchkis lower control arms
    Eibach Pro-kit lowering springs
    Bilstein shocks
    Powerstop Cross-drilled rotors
    Fairies Drive Imports camaro_five0's Avatar
    Clarksville, TN
    Sunset Orange Metallic
    2002 Camaro SS M6
    I only got a few things for the suspension, cuz I think it's all I really need!
    Spohn SFCs
    Spohn STB
    Spohn LCAs
    Spohn LCA relocating brackets
  1. Question: Suspension Mods
    By jambofla in forum Suspension and Handling
    Last Post: 02-28-2009, 07:32 AM
  2. suspension mods
    By stangslayer98 in forum Suspension and Handling
    Last Post: 08-13-2008, 12:35 PM
  3. what suspension mods??
    By blue02Z in forum Suspension and Handling
    Last Post: 10-08-2007, 01:52 PM
  4. $2000 on suspension mods or on motor mods??
    By greatwhiteZ28 in forum Suspension and Handling
    Last Post: 09-27-2007, 06:04 AM
  5. What should my first few suspension mods be??
    By NeeD4SpeeD in forum Suspension and Handling
    Last Post: 11-21-2005, 07:52 AM
