09-28-2005, 11:27 PM #1Junior Member
- Deltona, FL
Light Metallic Pewter- 2001 Camaro Z28
Tire Size Question 245/50 to 255/50
I'm thinking about going to larger 255/50s from the stock 245/50s.
Is this a good idea and what is the best brand to go with. Also is handling or anything else affected by switching to the wider tire?
Thanks
09-29-2005, 03:57 AM #2Rhino21149Guest255/50s will be slightly (about 3-4%) larger rolling diamter than 245/50s, diameter, so your speedo will be slightly off (saying you are going about 67 when you are actually doing 70. It also effectively changes the rear end ratio slightly, if you have a 3.42 axle ratio, with the slightly larger rolling diamter you'd have the equivalent of about what a 3.32 would do with stock tires.
Originally Posted by Cachels1
Handling might be better or worse-probably depends on the make a grade of tire more than the size with this slight change.
I think you'd be better to go to something wider with a different aspect ratio, say a 275/45 or 40 or some combination that is noticeably wider but with a smaller aspect ratio so it has the same overall rolling diamter. you could talk to the guys at tireRack about what would work out well - they have all those #s at their fingertips and you'll probably get the tires there for less than anywhere else.
When my 98 was new I switched out the original 16" tires and wheels for 18's with 275x40, I believe, a lot wider and the exact same rolling diameter. That made a big difference in handling, and stopping distances, too.
09-29-2005, 09:02 AM #3Junior Member
- Deltona, FL
I would like to switch to 275's & 17" rims, but cant afford it. Is there anyone out there who has 255/50 tires?
09-29-2005, 10:02 AM #4
check tirerack and discounttiredirect
search by size not by vehicle
and if handling is important look for a Z rating with a stiff sidewall
09-29-2005, 06:30 PM #5quicky06Guest
i have 255 45 17 on my rears and 235 45 17 on the front cuz the 55's wouldnt fit
09-30-2005, 04:17 PM #6Member
- any where but here
It is possible to find 245's that have a tread width of a standard 255. Look closely @ the tire information & you will find that some brands run wider than average on certain models. I did this w/ my 17's, found a 245 tire with a standard 255 tread width (not tire width, but, tread width).
If you still want a true 255, then you will likely find a greater slection in the 255/45 or 255/40 ratio than in the 255/50 ratio. Good-luck with your search.
Tire size question
By nmartin in forum Wheels and TiresReplies: 5Last Post: 10-21-2009, 04:27 PM -
tire size question
By blackz28ls1 in forum Wheels and TiresReplies: 3Last Post: 03-08-2008, 09:10 PM -
Tire size question
By 2000_Black_WS6 in forum Wheels and TiresReplies: 14Last Post: 03-05-2007, 03:48 PM -
another tire size question
By 94transamgt in forum Wheels and TiresReplies: 2Last Post: 06-20-2006, 11:00 PM -
size of tire question
By bbautox in forum Wheels and TiresReplies: 1Last Post: 01-01-2006, 10:41 PM
