12-26-2006, 03:04 PM #1Junior Member
- Jan 2006
- ar
2000 black T/A Vert- Red 99 C5 Coupe sold
Just bought a 6.0 liter! What Heads and cam to should I use?
I am thinking about the new L92 heads and L76 intake, is there a better setup that is close to that price? I will be doing this over the next few months as I get the money.
From what I have read I need the:
L92 heads
L76 intake
New intake rockers
Cam
90 mm TB (the OEM one is drive by wire)
I have headers, will they work on the L92 ex ports?
I am leaning this way because of the price, and the article in GMHT put the motor at 546 (I think) hp.
Thanks,
Shawn
12-27-2006, 07:47 AM #2
for the price, the L92 heads are hard to beat.
12-27-2006, 08:40 AM #3Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
That is definetly the hot set up
As for the cam you'll need some thing over 230 duration to equal the numbers from the Magazine. Maybe a MS4, don't know how streetable that set up will be though ?
Seems to me that it should be alright. Remember you'll need the 6.3 head gaskets also.
The exhaust ports sit higher than a stock LS1 so your headers may be alright depending on how tight to the floor they are right now.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
12-31-2006, 11:06 PM #4
Personally I would stick with the 243 head, scallop the chamber to 4" and get a decent 215cc port job done. There is such a thing as too much flow, and Im not convinced the L76 heads are well suited to the 6L just yet. And you can re-use all your old bits.
For a cam, anything 228-232 up till 236-240
6 Liter 317 Heads
By FRCBobby in forum Parts For Sale / TradeReplies: 0Last Post: 12-17-2007, 04:18 AM -
5.3 liter Patriot Heads on LS1
By 9t8z28 in forum Internal EngineReplies: 5Last Post: 11-06-2007, 06:59 AM -
5.3 liter heads
By 92ZZ3RS in forum Parts For Sale / TradeReplies: 7Last Post: 03-30-2007, 03:29 AM
