    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    Power usage for '98 camaro dome light
    Okay, here's a question I have not been able to find the answer to:
    How many amps does the stock dome light (over the rear passenger seats) use?
    South Bay
    1998 Camaro Z28
    Okay, never mind. I found the answer. The #561 bulb uses 0.97 amps. Wow! I guess it does make sense to replace all the stock bumbs with LEDs; or even groups of LEDs!
    So apparently, for all the LEDs I've installed for my interior lighting, the power consumption comes out to about 9% of the power used to light the 1 stock filament bulb. Again, WOW!
    Cape Coral, FL
    Mystic Teal
    99 Trans Am & 01 CBR 929
    hmm good info thanks
    weberje
    Guest
    hey, that's good information! Something I will consider in my work up.
    weberje
    Guest
    Cobrahunter,
    Could you share some of what you've replaced? I would like to look into that venture.
    South Bay
    1998 Camaro Z28
    I've replaced the stock dome light with 4 LEDs, and the map lights with LEDs.
    I have added several LED light bars by the foorwells and well as under the seats. I also added LEDs in the engine.
  1. key off dome light on
    By SS II in forum Stereo and Electronics
    Last Post: 07-09-2012, 04:40 PM
  2. LED Dome Light F-UP
    By Maximus0066 in forum Appearance Section
    Last Post: 10-31-2011, 11:25 AM
  3. Map & Dome Light Mods
    By YellowTA in forum Appearance Section
    Last Post: 09-22-2009, 05:20 PM
  4. Replies: 2
    Last Post: 07-25-2007, 05:32 PM
  5. Replies: 5
    Last Post: 05-15-2007, 09:43 PM
