    Junior Member Mr. Anderson's Avatar
    Jun 2006
    Independence, MO
    2000 SS is Higher on Driver's Side (Rear)
    I noticed on my sons 2000 SS that the clearance between the top of the rear wheels and wheel openings is huge, but on the driver's side it is almost and inch higher than the passenger's side. I'm speaking in terms of "higher", because the passenger side clearance is still 3+ inches so the driver's side is even more. It's ridiculous, but then again maybe 4 inches (driver's side) of clearance is normal? The car is stock.
    On a level surface you can actually see the difference from the rear. The car leans to the passenger side.
    Can anyone explain this? I'm thinking bad spring on the passenger side or bad "something" on the driver's side?
    Thanks for your input.
    Jun 2006
    Independence, MO
    Either I didn't explain this problem clearly or it must be a freak of a car since nobody has responded?
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I always thought the driver-side was a bit higher. Then would level out when you sat down.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Jun 2006
    Independence, MO
    Thanks for the response.
    I guess that makes sense, except our other cars sit level. Maybe GM planned for the Camaro to actually be driven?
    If it's not a big deal, I won't worry about it.
    I'll be doing a suspension upgrade is a few weeks so I'll check it again then.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    All the cars are biased to the driver side height and off center.
    And adj Panhard will solve the centering problem.
    For the height check the spring orientation the lower end of the springs should point toward the front of the car.
    Mine had moved (twisted) over time.the car will still be taller on the left side but not as much maybe 1/2".
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
  1. driver side rear bumping noise
    By tomd530 in forum General Help
    Last Post: 12-29-2010, 04:58 PM
  2. 2000 Trans Am Driver Side Mirror
    By SENN13 in forum Parts Wanted / Trade
    Last Post: 04-10-2009, 01:55 PM
  3. 2000 firebird driver side light assembly
    By firebird811 in forum Parts Wanted / Trade
    Last Post: 10-01-2007, 05:15 PM
  4. Rear end higher on one side than the other
    By John Ceta in forum Suspension and Handling
    Last Post: 08-23-2007, 09:55 AM
  5. Driver side window off track 2000 Trans Am WS6
    By andybcrazy in forum General Help
    Last Post: 05-16-2007, 04:13 PM
