Results 1 to 16 of 16
Thread: Torque Arm Relocation Bracket?
12-21-2006, 02:29 PM #1
What exactly does the toraue arm relocation bracket do? i know it takes the load off the rear tailshaft, but what exactly does that mean? I think i have a broken trans mount and i am conteplating just getting the relocation kit for better strength, but i really dont know much about it. Any help from those who have 1 or those who know about them would b great, thanks.
12-21-2006, 02:37 PM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
it moves it off the trans. what the brackets do with a adj. torque arm is alow you to center your rear and you dont run the risk of breaking/cracking the trans housing. they move the torque arm to a more efficent area where it will be able to do its job a lil better. but you need a adj t-arm if you get the relocation kit. hope this helps.
12-21-2006, 02:49 PM #3
oh ok so, i would need a new adj. torque arm as well. Do u think these mods are worth the money?
12-21-2006, 02:58 PM #4
Also, how do adjust ur t/a bracket and t/a? I mean, what angles does this stuff have to be set at to get the most out of your car?
12-21-2006, 02:58 PM #5
12-21-2006, 02:59 PM #6
12-21-2006, 04:47 PM #7
there are a couple designs out there.
spohn has this version that includes a driveshaft loop welded onto the trans crossmember
http://www.spohn.net/productimages/405_big.jpg
bmr has two ways to do this as well
this one takes the arm off the transmission and allows you to adjust the instant center. this can be good for braking as well as acceleration. can be used with stock arm, or any aftermarket arm that would normally hook to the transmission.
http://bmrfabrication.com/misc/TCC006.jpg
this one comes with a crossbrace that you would weld to the car. preferably to subframe connectors. it's shorter than the stock arm which changes the instant center. downside is running true duals will be a problem.
http://bmrfabrication.com/Xtreme/XTA001.jpg
other manufacturers make just about the same thing.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
12-21-2006, 06:25 PM #8
12-21-2006, 06:26 PM #9
sometimes
12-21-2006, 10:01 PM #10
That helps a lot, thanks. Well, im now thinking the BMR 1. What do u run on ur car mrr23?
12-22-2006, 12:28 PM #11
12-22-2006, 01:25 PM #12Just me
- Nov 2006
- Broken Arrow, OK
I know if you have a lowered stance, you want to avoid the Spohn relocation kit like the plague. There have been a lot of posts and issues with it on tech, people have posted pics of it, and if you have any kind of drop, you will drag the relocation kit.
12-22-2006, 01:52 PM #13
12-22-2006, 02:14 PM #14Crazy Canuck !
- Jun 2002
- Montreal, CANADA
the bmr version is great for acceleration only... not braking... the short version of TA will creat massive wheel-hop on braking.
There is a design which is better, but has its price... it's the UE (unbalanced-engineering) version
http://www.unbalancedengineering.com/Camaro/
This TA actually acts as a short one during acceleration and very long one while braking... imho, WAY better than what BMR offers, but @ a price.Eugenio_SS
12-22-2006, 02:16 PM #15
i help a friend install the UE in his 98 z28. for someone autocrossing and such, it is a great one to have. you have to drill into your floorpan to install it. and it's real fun getting the right adjustment.
can't say i ever experienced any braking isuues.
12-25-2006, 01:10 PM #16
Anyone got a adjustable torque arm/relocation bracket? Sales
By eddielb in forum Western MembersReplies: 3Last Post: 09-13-2011, 06:12 PM -
Anyone have a torque arm relocation bracket?
By km346 in forum Suspension and HandlingReplies: 12Last Post: 07-22-2011, 06:45 PM -
Wanted: torque arm relocation bracket
By joedude02 in forum Parts Wanted / TradeReplies: 0Last Post: 10-24-2009, 07:01 AM -
By Patsy57 in forum Suspension and HandlingReplies: 10Last Post: 04-11-2008, 06:47 AM -
UMI T/A & Relocation Bracket
By Jon7I2 in forum Suspension and HandlingReplies: 36Last Post: 03-24-2007, 05:25 PM
suspension mods are the best mods.
try getting stickier tires and better braking compound... brake-hop is way more aggressive than acceleration wheel hop... you feel like a giant is playing basketball with the rear of the car.
