12-19-2006, 07:01 AM #1
Sirius radio install, where did you put it?
Hi, I bought a SP4-TK1 Sportster 4 Radio for my '01 Z28.
Does anyone have this unit installed in their car? I’ve had a real problem finding someplace to put the receiver. I’ve already broken one air vent on the center console with it. Suggestions?
I've got the antenna just sitting inside on the back of my trunk area, no issue there.
Willdog
12-19-2006, 09:42 AM #2
- Cape Coral, FL
Mystic Teal- 99 Trans Am & 01 CBR 929
drill a hole in the bottom of your center console to run the wires and put the mounting bracket and everything right in there.. That is where I have my reciever at. I didnt wanna mutilate my car by drilling anywhere else. It is nicely concealed and if you wanna change the station you can just pop open the console at a light and use the presets..
12-22-2006, 07:24 AM #3
12-22-2006, 07:49 AM #4
- Cape Coral, FL
I still use my remote from time to time just so I dont have to reach into the center console, I just keep it in my cup holder but you are right you would not need it. However the only way you would need it on these cars is if you mounted it on your dash somewhere out of reach. You could however also use double sided tape and have the bracket mounted on your windshield but that would be much harder to hide the wiring.I am just trying to gue suggestion for places thatit could be easily removed if need be..
01-03-2007, 04:09 PM #5
- Sep 2006
- Willoughby,Ohio
Black on Black- 2000 Trans Am Ws6
Circuit City makes a universal bracket that will place the reciever just right of your radio and use factory radio bolts to hold it so no drilling and the wires run right behind front facing so no drilling for the wires either. Believe the bracket is like 31.00 dollars. Heres the link
http://www.circuitcity.com/ssm/Metra...oductDetail.do
Sirius Satt Radio w/FM Modulator Fun
By Sarge in forum GTOReplies: 6Last Post: 05-22-2010, 12:49 PM -
Sirius Satt Radio Fun
By Sarge in forum Almost Anything GoesReplies: 15Last Post: 01-14-2009, 12:30 PM -
Sirius and XM Satt Radio merge
By Sarge in forum Almost Anything GoesReplies: 10Last Post: 02-22-2007, 07:15 AM -
Sirius Satellite Radio, Car Kit, Executive Home Kit
By 93Bonny in forum General ClassifiedsReplies: 2Last Post: 09-01-2006, 11:21 AM
