Thread: advice please
    dblanch35
    Guest
    advice please
    anybody ever pulled automatic trans out of 02 convert?
    lost 3rd and drive after playing the other night.
    thought it was the rearend at first. can't seem to get to the upper bell housing bolts. its lke the motor needs to drop some.
    advice welcomed. just gona do a swap out
    Aug 2006
    Sanford, Florida
    Impulse Blue Metallic
    04 GTO
    This should help you out I just changed out the trannt in my 04 GTO very similar to the f-bodys.
    http://modernmusclecars.net/forums/a...p?do=tcinstall
    dblanch35
    Guest
    thanks;
    that does help but i still am having trouble geting to the top bellhousing bolts even with the proper lenth extension and a swivel socket.
    when i removed the crossmember antd other stuff to my suprise the motor did not drop much at all. so was wondering if i would need to losen the motor mounts are something. would rather not.
    thanks again
    I will get it out i was just looking for a easier way or something.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Lowering the tranny should have given you enough room. The alternative is to pull the intake manifold and get it from the top.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    What kind of exhaust do you have, the last tranny swap I did, the duals were keeping the tranny up too high to access the top 2 bell housing bolts. Once we got around the duals, it dropped low enough.
    Also, you might try your local Autozone, bought 2 huge ratchet extensions that made it a lot easier.
    Painted manta stripe
    Those bolts are a bear to get out. I used a series of smaller extensions and those seemed to help due to giving you a little more wiggle room. I used a buttload of 3" extensions that let me get at those bolts from the rear of the tranny. Having a helper under there to hold the light and direct you comes in really handy too.
  1. Need advice, possibly legal advice
    By JHayesLS1 in forum Almost Anything Goes
    Last Post: 12-19-2009, 09:23 AM
  2. Need serious advice...alot of advice. Long.
    By !!!FAST!!! in forum Almost Anything Goes
    Last Post: 10-31-2007, 07:49 PM
  3. Need ADVICE
    By dblanch35 in forum Automatic Transmission
    Last Post: 12-16-2006, 10:56 AM
