Thread: Tuning lingo
12-16-2006, 12:25 AM #1Need Sand ???
- Aug 2006
- Sandbox, Kuwait
Black- 06 Chevy Caprice HT (RIP)
Tuning lingo
What on earth is Speed density tuning?
What are the pros and cons?
12-16-2006, 04:03 PM #2
Speed Density IS OLD SCHOOL COMPUTER SH_T!!!!
It is a equation that the computer figures off of pre set table values on multiple sensors...... It is before they came up with a mass air flow sensor.......
Basically if you have a speed density set-up and do some mods on the motor it can NOT compinsate for those changes UNLESS you go back in the programming and change the values on the different tables.Don't be afraid of the bottle!!! Be afraid of your tune!!!
01-03-2007, 11:37 PM #3BOSSONNOS
- Oct 2005
- AUSTRALIA
Turismo Blue- 2005 Holden 502rwhp
SD tuning still has it's place, especially with FI, a maf will eventually max out.
SD is mainly for race cars but we do tune a lot of street cars this way and gain approx 10 - 15 hp over a maf.
01-04-2007, 05:22 AM #4Need Sand ???
- Aug 2006
- Sandbox, Kuwait
What if you got a bigger Maf sensor with its proper table...I know the GM one is good for about 600hp...But lets say i have a 100mm MAF sensor, could i gain a little on a 400hp engine?
01-04-2007, 01:35 PM #5BOSSONNOS
- Oct 2005
- AUSTRALIA
If you run a bigger maf, yes you can make more power, as far as i know the Maf on your vehicle is the biggest you can get, should be good for around 450-470 hp atw, any FI engines I do I tune in SD, Had turbo's and a few s/c engines driving around for sometime now on sd tunes and have no problems, if time is spent on setting up the sd tune correctly you won't have any problems, if the tuner does not have experience with tuning in sd he will tell you that going sd is a waste of time, as a tuner sd can do your head in at times but as i said once set up it make awesome smooth power and be reliable.
Check on the Australian LS1 forum and see how many of the people on there run s/c engines with maf's, almost none, and most of them run sd tunes with and without cam changes.
Heads up for the guys new to womens Lingo
By Crimson Sin in forum Almost Anything GoesReplies: 17Last Post: 01-31-2009, 05:05 PM -
a little help understanding the lingo 4 us new guy
By adam0321 in forum Firebird / WS6Replies: 1Last Post: 07-06-2008, 01:34 AM -
LS1.com Slang Terms and Lingo
By Spikito in forum General HelpReplies: 58Last Post: 05-12-2008, 01:22 PM
