    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    4:10 and Paddle Pin Kit
    Probably been ask many times but I can't find a definitive answer. My 2000 M6 Z28 has all the bolt-ons I am going to perform and doing the gears will be the last mod for now. I plan to have 4:10 installed but do all the manufactures require a Paddle Pin Kit? If they don't mention it in their ad like SLP does can I assume one is not required for their particular brand? Yes...I know what a s s u m e means. A little advice please.
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    doylestown, Pa
    SILVER
    2004 CTS-V
    Yes, you need the paddle pin kit IF you have a Zexel Torsen Differential and are installing 4:10 gears. I am pretty sure, but not positive, that you do have a Zexel. The standard Paddle Pin is one piece. The SLP Paddle pin is 2 pieces because there is no way to get the standard (1 piece) pin in without grind the ring gear.
    Navy
    2000 Z28 M6
    Sort of what I was thinking. Big price to pay on top of the gears and installation. Thanks for the feed back.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by 89LX View Post
    A friend of mine is looking into producing his own paddle pin kit. SLP wants way to much money for it. It is a simple machined piece.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    when i did my 4.10 gears, i just ground a little off the paddle. just enough to clear.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Wow! Thats alot different than mine. I could have ground the pin but it was easier to buy it at the time.
    Glen Carbon, IL
    I don't have any pics, but I ground a couple of grooves in the paddle to slide past the teeth. I did it this way so the paddle would still hold the torsen gears evenly. I put the paddle in as much as I could and marked 2 lines where to grind with an angle grinder. I don't think that grinding the entire side of the paddle is good for the torsen diff.
  1. LSX Camaro /w paddle mod vs. '03 Cobra
    By Superluminal in forum Kill Stories
    Last Post: 06-27-2009, 10:57 AM
  2. Paddle Shifter for the 4L60E
    By MikeSomething in forum Automatic Transmission
    Last Post: 05-22-2008, 05:48 PM
  3. paddle shifters
    By LT1 > LS1 in forum Automatic Transmission
    Last Post: 01-09-2008, 07:34 PM
  4. WTB torsen 3 series paddle
    By deepstage69 in forum Parts Wanted / Trade
    Last Post: 07-18-2007, 05:40 AM
  5. C6 Paddle shift trans.
    By C6 Twin Turbo in forum Corvette
    Last Post: 09-07-2006, 04:01 PM
