Thread: What gear oil for 12 bolt?
12-11-2006, 07:46 PM #1
What is the best gear oil for a street driven strange 12 bolt. it has posi so i know i need 2 bottles of gm posi additive. But what do you guys think is the best brand/weight for them and how much will i need?
00' ws6, custom paint, bolt on's and bolt in's.. http://www.fquick.com/garages/viewvehicle.php?id=11454
12-11-2006, 09:01 PM #2stab it and steer it!
- Aug 2006
- illinois
red- 99 Z28 SS convertible
i would use like an 85-140 high grade(synthetic) type lube. like Amsoil or Royal Purple. if you are track only, then you can get by with a lesser viscosity. although i would purchase same brand additive as the lube, the stuff you have will probably be fine.
12-11-2006, 09:17 PM #3
12-12-2006, 05:34 AM #4stab it and steer it!
- Aug 2006
- illinois
yes, non or semi-synthetic will be fine, also.
12-14-2006, 02:01 PM #5
Neither Strange, Moser, or Eaton recomend syn gear oil for their Eaton posi's. Just use a dino gear oil. It will hold just under 2 quarts.
12-14-2006, 02:04 PM #6
the chevy house reccomended 85w 90 for 12 bolts, strange said the same. so i guess thats what i should run. i just wanted to see what everyone else was using and which was best. thanks for the info guys
oh yeah... and will a heavier weighted oil help deaden some of the gear whine?
12-17-2006, 03:08 PM #7
don't forget the friction modifier
12-18-2006, 05:23 PM #8
syn. is a no go for the rear.
12-18-2006, 05:28 PM #9
For Sale: 10 Bolt Rear-End, Eaton HD Posi, 4:10 Gear
By '99 SLP#24 in forum Parts For Sale / TradeReplies: 20Last Post: 05-23-2010, 06:11 PM -
rear end gear for 7.5 10 bolt
By slikws6 in forum DrivetrainReplies: 3Last Post: 03-15-2008, 06:03 PM -
12 bolt gear install kit
By BlackHawk in forum Parts For Sale / TradeReplies: 1Last Post: 08-16-2007, 08:55 AM -
4.10-4.11's 12 Bolt Gear
By BlackHawk in forum Parts Wanted / TradeReplies: 0Last Post: 06-26-2006, 02:22 PM -
10 bolt gear install kit F/S
By mmorrison09 in forum Parts For Sale / TradeReplies: 1Last Post: 11-29-2005, 10:08 AM
