    any where but here
    Where to find this size tire
    Anyone know where a performance tire 255 or 275 (40 to 50 wall) for a 16" or 17" wheel no larger than 25" o.d. can be found? Can find 25.6" or 25.7", but, no 25" or less until down to 245's. Thank-you
    Midwest Member Topless TA's Avatar
    Kansas City Suburbs
    WS6 M6 Vert
    Quote Originally Posted by LS1-450
    The math is the math,
    275 40 17 25.66141732
    265 40 17 25.34645669
    255 40 17 25.03149606
    245 40 17 24.71653543
    245 50 16 25.64566929
    225 50 16 24.85826772
    Go to tire rack or discount tire direct to check out some sizes
    The 275/40/17 or 245/50/16 are both factory sizes that fit the TA and Camaros 4 gen body.
    Member Duffster's Avatar
    Hamilton, Illinois
    2001 Camaro Z28
    I used 245/35/16 Pirelli P7000's for almost a year. If I remember, they're the
    stock size and tire for Mazda RX-7's.
    Got 3 good ones in my garage right now. . .
    st. cloud, MN
    1999 camaro z-28
    I had 255/50/16 on my stock rims. They were falken tires, I got them on tires.com. I thought since they were a little wider they'd last longer, but 10.000 miles later I replaced all four of them. I do my fair share of burnouts, but I was hoping for at least 20,000.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    just remember how to calculate it.
    Let's take the example of 275/40-17
    that means the tire is 275mm wide.
    40 means the sidewall is 40% of the width... ie, 40% x 275mm = 110mm
    so each sidewall is 110mm, but in inches, that's 110mm/25.4 = 4.33" per sidewall.
    there are 2 sidewalls... ie 2x 4.33" = 8.66"
    The most obvious measurement is the 17, means the diameter of wheel.
    overall diameter = diameter of wheel + 2x sidewall.
    OD = 17" + 8.66" = 25.66" for a 275/40-17
    Have fun playing with different combinations and getting the OD... hope this helps.
    Eugenio_SS
  1. Do you find plus size/thick/big girls attractive?
    Last Post: 12-23-2014, 08:55 AM
  2. tire size questions to the tire gurus!
    By vonskeezy28 in forum Wheels and Tires
    Last Post: 04-30-2011, 09:01 AM
  3. Need to find out what the best street tire is
    By 99TransAmSLP in forum Wheels and Tires
    Last Post: 02-11-2009, 05:25 PM
  4. Tire size for C6 rim
    By Bigsword4 in forum Wheels and Tires
    Last Post: 03-19-2007, 07:43 PM
  5. Where to find & what size pullies for DS1?
    By Jerry's 99SS in forum Forced Induction
    Last Post: 02-26-2006, 03:35 AM
