Results 1 to 11 of 11
    Got Juice? Nasty TA's Avatar
    Knoxville, TN
    2002 Trans Am WS6
    Hard wiring wideband into computer
    Does anyone know is you can hard wire a wideband in to the ls1 computer so it can runn of of the wideband instead od the factory O2's? You can tap into some computers on some cars but haven't seen anyone with this on an Ls1 yet. If you have seen this or know how to do this i would appreciate the info. Thanks
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Only way to incorporate a wideband instead of a narrowband O2 is by using an aftermarket setup that can output a simulated NBO2 signal. AEM has such a setup. The factory computer can not use the 0-5V signal from a conventional WBO2. They are WBO2 that output (or operate) with 0-1V like NBO2 sensor, but they are extremely expensive ($1000+/per) for such use.
    George P. Lara
    Mine 2001 Camaro SS #0391: FQuick Garage
    Mrs.'s 2002 Camaro SS #7072: FQuick Garage
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Really? I just hooked a LC-1 in place of a NB sensor. Sending one output to the PCM and the other to a WB gauge/EFILive. Have not tested out the WB, but I think it will work.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Ed,
    That is one of very few aftermarket widebands that I know that will output a signal similar to the NBO2 sensor. All of which will require a controller, non of which will just plug right in.
    Aug 1999
    No Where
    Good to know.
    Need Sand ??? Naf's Avatar
    Aug 2006
    Sandbox, Kuwait
    06 Chevy Caprice HT (RIP)
    But which wire is the 1 volt wire on the NBo2?
    Typically?
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    So the LC-1 will work as a replacement for the stock NBO2 sensor?
    Member Orange SS's Avatar
    Palm Bay, FL
    Ermine White
    1964 Chevelle
    PLX also has NB outputs
    FJO Racing... the folks who made the NX Maximizer have a wideband with two programmable analog outputs, or pick one of the built in presets, like 1-0V, 0-1V, 5-0V, 0-5V...
    Twin Turbo Terror anarchy99's Avatar
    Memphis, TN
    00 WS6 Trans Am
    Hope this helps for the LC-1 guys. Shows how to wire up the LC-1 to be used as a NB and WB in your EIO box. also shows what wires to tap into on the stock O2's.
    http://www.audiohelix.com/tuning-documents/lc1/lc1.htm
    if your car has EGR (and you have removed it) you can use the wires from it to connect to the computer as well. There is a write up on this for HP Tuners website.
  1. Wanted: LS1 low mileage with wiring harness and computer
    By IcantDo55 in forum Parts Wanted / Trade
    Last Post: 10-14-2009, 08:54 AM
  2. LS1 computer & wiring
    By sammy burks in forum Parts For Sale / Trade
    Last Post: 02-09-2008, 02:06 PM
  3. Need help hard wiring radar detector
    By gettin sideways in forum Stereo and Electronics
    Last Post: 08-26-2006, 08:28 AM
  4. ls1 computer and wiring harness
    By CamaroMotorsports in forum Parts Wanted / Trade
    Last Post: 07-28-2006, 10:02 AM
  5. is computer on 98 hard to tune vs 99 and up
    By cannotbeheldliable in forum Computer & Tuning
    Last Post: 05-21-2006, 10:50 PM
