    UMI Suspension Questions
    Hey Guys,
    I just ordered non-adjustable LCA's and panhard rod for my 98 A4 Z28. I plan on replacing the torque arm in a couple of weeks as well, and was wondering if I should invest in a non-adjustable or adjustable. I don't plan on altering the ride height (ground effects + lowering = scuffed paint), but I want to make sure that it hooks up like it used to before all of the stock bushings turned to play-dough. Thanks!
    It is better to pay the extra for the adjustable.
    I was the same wanting to keep my cat at stock height but things change.
    I am considering ordering the Strano lowering springs this winter.
    Besides it is nice to be able to adjust the pinion angle for racing/street!
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    I believe you need to have adj LCA and adj torque arm together.
    And even stock ride height cars need an Adj panhard bar to center the rearend correctly because the rearends are biased toward the driver side.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Junior Member dixieboy's Avatar
    South Carolina
    torch red
    1999 T.A /A4/ T-top
    Any Time You Can Adj. A Part It Makes It Better. You Can Lose 2 To 4% Of Your Power, From Drivetrain Angles To Great.the Strighter Your Drive Shaft At Lach The Beter, But You Have To Have 1 Degree Of Angle To Keep The U-joints Together
  1. Suspension questions
    By Durango in forum Suspension and Handling
    Last Post: 02-09-2011, 07:27 PM
  2. a few more suspension questions
    By 04cosmos in forum GTO
    Last Post: 04-23-2009, 05:01 AM
  3. Suspension questions...
    By BlackLT1Z28 in forum LT1
    Last Post: 10-29-2007, 09:11 PM
  4. Suspension Questions???
    By LIVINGTHEDREAMLIFE in forum Firebird / WS6
    Last Post: 04-26-2006, 03:26 PM
  5. Suspension Questions...
    By LS1 Eddie in forum Suspension and Handling
    Last Post: 12-23-2005, 05:12 PM
