Results 1 to 3 of 3
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Exclamation 1970 Ford Boss 302 Mustang - Urban Legend
    Steve Sclimenti build his dream 1970 Boss 302 Mustang with vintage Trans-Am looks but modern performance.
    More...
    Impounded The Answer's Avatar
    California
    2002 SS
    I've always had an affinity for the Yellow Boss 302 and my very first hot rod was a 1967 Fastback GT with Boss 351, Top Loader and 9" 31 spline 4:56 gears.
    I used to love the way I could remain motionless while spinning the 'ol GoodYear M50's until I was invisible from the smoke and so did everyone else.
    This post reminds me of how much of a dummy I am when I sold my monster for $1500.
    Would probably be worth about 50 grand + on Barrett Jackson now.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Engine: An SVO Ford 351W Block was stuffed with a Scat crank to push displacement out to 408 ci with Carrillo rods and JE pistons squeezing out a 12:1 compression ratio. A 0.673-inch-lift Comp Cams solid roller with 107-degree lobe separation opens stainless 2.10-inch intake and 1.625-inch exhaust valves in the 225cc Edelbrock Victor heads massaged by Chapman Racing. Cometic gaskets keep the top end sealed. A Yates mechanical fuel pump sucks fuel from a 22-gallon ATL fuel cell to feed a Holley 750-cfm that's been reworked by Dave Lang at Fuel Curve West to flow 960 cfm into the Edelbrock Super Victor intake. A full MSD ignition utilizes a Pro-Billet distributor with dual pickups to control the NASCAR-style dual-ignition system setup.
    Power: The high-strung small-block churns out a healthy 655 hp at 7,200 rpm with 555 lb-ft of torque and has to be able to for extended periods on the track.
    nice.
  1. 2012 Ford Mustang Boss 302 - The Boss Is Back
    Last Post: 08-19-2010, 06:12 PM
  2. 1970 Ford Trans-Cammer Mustang - All Business
    Last Post: 04-27-2010, 05:44 AM
  3. 1969 Ford Mustang - Tasca Super Boss
    Last Post: 06-29-2009, 10:50 PM
  4. 1993 Ford Mustang LX - I Am Legend
    Last Post: 04-22-2009, 12:03 PM
  5. help me clear up this urban legend
    By whitelightnin99 in forum Almost Anything Goes
    Last Post: 05-02-2006, 10:21 PM
