Results 1 to 20 of 20
Thread: iPod Question
11-29-2006, 06:45 PM #1Junior Member
- Oct 2006
- New York
- Blog Entries
- 2
pewter- 2000 Trans Am
iPod Question
I've been reading some stuff about the iPod jack for the 98-02 trans am. and some say you need a tape player and/or a source button. i don't have either is there anyway to still connect it in?
11-29-2006, 07:32 PM #2back 'n better than ever
- Norman, Oklahoma
White/Black- 1999 Z28
I have an aftermarket alpine headunit. Usually the easiest way to use your ipod in the car is with an FM transmitter or the tape adapter, but I've heard that the song quality is not as good. To directly connect to your headunit they make a cable that plugs into your headphone jack on your ipod, and into the input jack in the back of your headunit. If you don't have an input, like mine did, they made an adapter for about $50 that plugged into the output... and then into my ipod and also wired in and charged it.... not sure if that will work on a stock headunit though.
11-30-2006, 02:11 PM #3Junior Member
- Oct 2006
- New York
- Blog Entries
- 2
yeah but wat about with the stock head unit in
11-30-2006, 02:16 PM #4
yes it will work with any gm radio. You just need the gm kit harness. i have one if you need one.
11-30-2006, 02:42 PM #5
They have this kits on Ebay here is the link.
http://cgi.ebay.com/PERIPHERAL-PXGM9...QQcmdZViewItem
12-01-2006, 05:28 PM #6
Yeah, this was initially what I was going to go with. But then I decided, among other things, that I wanted to control the ipod from my deck.
12-04-2006, 03:39 PM #7Junior Member
- Oct 2006
- New York
- Blog Entries
- 2
if you use that harness kit can you control it with the track buttons?
12-04-2006, 04:14 PM #8
The ipod harness I have I purchased at the stereo shop I got my deck from. I don't know if it is the "GM" harness, just that I can totally controll my ipod from my Alpine deck.
12-06-2006, 05:47 AM #9Junior Member
- Mar 2006
- Houston, Tx
Red- 2002 WS6 Trans Am
http://www.crutchfield.com/S-ki2Qwe7...spec+auxiliary
This is what you need. It controls the iPod from your factory radio. Through the iPod wherever you want, you don't have to even look at it. Crutchfield is always out of stock but there are other sites that have it, I think you can also go to a Tweeter store and get one.
12-06-2006, 05:52 AM #10Junior Member
- Mar 2006
- Houston, Tx
Sorry, the above post is wrong. That one is just to connect any audio device with right left inputs.
Here is the real link for iPod control.
http://www.crutchfield.com/S-ki2Qwe7...=usa+spec+ipod
12-06-2006, 09:03 AM #11
DAYUM for that much I would rather get SFCs. I bought an FM transmiter from best buy for $39 and it works great. Here is one that looks better than mine, cost a little more.
http://www.bestbuy.com/site/olspage....=1127210996478
12-07-2006, 02:45 PM #12Junior Member
- Oct 2006
- New York
- Blog Entries
- 2
i found this if anyone else is looking for it
http://www.icarkits.com/advanced_sea...icle=1&sort=4d
12-17-2006, 12:22 AM #13
I have this one:iPod2Car (PXHGM1) Peripheral Electronics, as posted above and it works great with the stock head unit.... You do however have to get rid of the cd changer to used this, if you have one. But you can control it through the steering wheel controls and the controls of the stock head unit. Just have to hit the Aux button. the sound is high Quality.
12-21-2006, 09:57 AM #14Junior Member
- Oct 2006
- florida
red and black- 02TransAm WS6 & 2011 2SS
Ok...I have a question...Just got a JVC H/U that advertises it's self as ipod ready. My husband got it for me for Chrsitmas, so I wasn't there to test it out...it has a USB port that will play from a jump drive and they said that you can hook up your ipod to the USB and it will play from there too...only problem is, it doesn't. Jump drive works, ipod doesn't. I 've called around and Best Buy says it should work that they installed the same HU in other cars and it works fine through USB, JVC says I will need to purchase an Interface adapter......anyone know?
12-21-2006, 10:01 AM #15Junior Member
- Oct 2006
- florida
One other question....I have a Mac at home w/ all my music on it. I put a few songs on my jump drive to see if it would work w/ my JVC and it did. So I went back to put more music on it and now my Mac will not use the drive. It will not let me copy to or from or delete.....but the jump drive works fine on a PC? Did the JVC fry my jump drive?
This is why I like Panasonic....
12-21-2006, 07:24 PM #16
12-21-2006, 11:15 PM #17
I had to download some drivers to my IPOD so it worked properly , might want to check into that .
2002 SS, M6, Volant CAI,SLP 345hp pkg,MSD 8.5 plug wires,NGK TR6 plugs,SLP Loudmouth and CME,SLP IAT,SLP Billet steel flywheel, Centerforce Dual Friction Clutch,Bilstien 2LE Susp,BF goodrich ta/kwd's, 341.9 RWHP and 362.7 RWTQ
12-22-2006, 06:42 AM #18
01-03-2007, 04:13 PM #19
01-04-2007, 06:44 PM #20weberjeGuest
With some head units, if you interface the I Pod from the rear HU aux port, then you lose the ability to navigate the I Pod and have to do it thru the HU instead. One HU I was looking at had you searching thru your songs alphabetically, and it was a PIA. As always, do your research.
IPOD question
By El Toro Loco in forum Almost Anything GoesReplies: 2Last Post: 01-30-2010, 05:08 PM -
iPod / iTunes Question
By 01 SS Vert in forum Almost Anything GoesReplies: 15Last Post: 04-08-2009, 09:15 AM -
Ipod input question
By squeals99 in forum Stereo and ElectronicsReplies: 1Last Post: 11-05-2007, 12:38 AM -
iPod question
By bmyers in forum Almost Anything GoesReplies: 2Last Post: 10-28-2007, 02:59 PM -
Ipod question
By kookamunga in forum Stereo and ElectronicsReplies: 20Last Post: 11-10-2006, 06:49 PM
