Results 1 to 17 of 17
    San Diego
    1999 Camaro Z28 (SS kit)
    Thumbs down Why does my Y-Pipe always hit the body!! How can I fix this??
    I am going to an exhaust shop tomorrow. I am using the stock y-pipe since the SLP hit my body all the time. I use SLP LM for the cat-back system, but this y-pipe is a nightmare. I am running 4.10 gears and NX wet shot as well…so my first to second shift is crazy...the y-pipe bounces up and down slapping off the body like an explosion.
    I have tried the bushing method in the past, but is there any other suggestions to keep this damn y-pipe from hitting the body under WOT? It is driving me crazy!!!!
    Thanks,
    Rich
    doylestown, Pa
    SILVER
    2004 CTS-V
    Give it more support? If you have good ground clearance, drop it down a bit?
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Your motor mounts are worn out that's why it's hitting
    Replace them with Polyurethane and you'll be set.
    Quote Originally Posted by 9T8W66 View Post
    My guess as well
    Painted manta stripe
    San Diego
    How hard is it to replace motor mounts? Is this something for a novice in the garage, or is it a bitch?
    Rich
    `98 Formula M6 HdTp
    You can do it but it's a PITA.
    San Diego
    Just found the Mufflex Bump stop for the y-pipe. my exhaust guy is putting it on for free to see if they should carry it to avoid so many camaro/firebird return visits with slaparoma.
    Thanks guys for all the help!
    Rich
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    I would still check out the motor mounts as others mentioned. The bump stop might quiet the slapping down but the torque on the pipe will still be happening and may cause it to start bending or leaks at the exhaust connections to the Y pipe. Just more of a classic fix the problem don't just cover it up until it really breaks. Good luck with it man!!
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    Bragg NC
    Met. Sunset Orange
    01 SS
    So your running stock manifolds and y pipe and its hitten the floor? Which side is hitten the floor? Check your mount on the pass side. The bumpstop works but i had too actualy cut my y pipe and weld in a new section too clear the floor board. but i have lt's and ory. If your running stock components then like said above its probly your motor mounts. Not too difficult too replace. If you go with poly mounts you will feel a lil more vibration while cruising but they will hold up better than the stock replacements.
    J
    Aug 2006
    West, Central, Florida
    2000 Pontiac Formula
    Quote Originally Posted by sunsetorangess View Post
    J
    x2. I'm wondering which side it's hitting on
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    I don't think it's the mounts (would be my second guess though)....GM made the y-pipe flat on the driverside for a reason. When you swap the stocker out for a bigger diameter Y there's just not enough clearance and it's going to bang the floorboard. My random-tech Y doesn't bang but it hangs low....the Y I made before the RT banged even under light throttle.
    I would first try to adjust it so it didn't bang. I had a very similar problem to this and was able to keep adjusting on it until I got it to stop banging. I found that the angle of the pipe coming over the axle is very important to getting the Y to line up to where it doesn't bang. Loosen the exhaust all the way back to the muffler and just play with those angles until you get it to stop. I also found it helped to lodge blocks of wood in between the exhaust and floorboard while tightening everything up then taking the wood out.
    San Diego
    I am an idiot! I have every suspension upgrade except a poly trans mount. Even though it was not torn, I replaced it anyway and the problem is solved. It was my trans that was slapping the body, not my y-pipe. Live and learn. I had replaced every other suspension part but this, and it turns out it was my prob....go figure. The car feels like a solid beast now, and I recommend this to any f-body for $25 and 40 minutes of your time...it is well worth it!
    Rich
    Bragg NC
    Met. Sunset Orange
    01 SS
    Sweet glad you figured it out and posted.
    J
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    I had the pros fabricate my y pipe from mandrel stock and install it, and it does not bang at all, I believe they used 2 1/2" stock, it does not hang any lower than the passenger side pipe.
    SteveC
    Member Sam-SS's Avatar
    Feb 2006
    Treasure Island, FL
    '99 Camaro SS
    I am having the same problem with a SLP Y pipe. Where is the best place to look for the Poly Mounts?
    San Diego
    Mufflex Bump stop for the y-pipe on Thunder Racing should take care of any y-pipe probs.
  1. Slp Headers,y-pipe For Lt1 F-body For Sale
    By zracer in forum Parts For Sale / Trade
    Last Post: 01-09-2012, 08:29 PM
  2. Wanted: SLP y-pipe and or catback for LS1 f-body
    By LS2GTO in forum Parts Wanted / Trade
    Last Post: 12-06-2009, 09:30 AM
  3. Ls1 F-body 00-02 Headers And Y Pipe For Sale
    By jkd4141 in forum Parts For Sale / Trade
    Last Post: 04-07-2007, 07:01 AM
  4. SLP y-pipe for '98-'99 LS1 F-body NIB
    By 98_1LE in forum Cowhands, Local Parts and Fish Bait
    Last Post: 07-22-2006, 11:28 PM
  5. BBK 80mm Throttle body or SLP Y-Pipe
    By tx77015ls1 in forum General Help
    Last Post: 05-14-2006, 06:17 AM
