Results 1 to 20 of 20
    LT1 modifications
    Ok so I have a 1995 caprice impala with a LT1 engine, what is your advice for add-ons to give me the most power form this engine.
    Thank you
    Start off with a CAI (cold air intake) then maybe a cat-back to make her breath better and keep going.
    The 'mod bug' should be sunk in by then and in the end you will probably have a stroked cammed monster like most of us end up with in the end!
    What cam are you talking about?
    Everybody gets custom grinds now so (almost) everyone has different spec's for different applications.
    Like drag, street, RR, etc.
    There are plenty of really fast impy's so you just need to research set-ups.
    i want it for drag, the only set-ups i found are the SLP heads
    Junior Member RAT454's Avatar
    Jun 2006
    Las Cruces New Mexico
    1971 Camaro
    Start with the basics
    leak down test check cylinder effecincy
    tune up
    synthetic oil
    run some good injector cleaner through it
    change the fuel filter
    increase intake air effeciency
    low restriction air cleaner and tube
    increase exhaust effeciency
    full flow system hedders
    computer modes
    chip/programmer etc
    fuel system upgrades
    the list goes on form there
    71 Camaro, roller cam 454 LS6, tremec TKO 600 5 speed, 2.56 gears, berlineta t-top, New Mexico plate "RAT454"
    74 Monte Carlo, 95 LT1 drive traIn swap, full computer,
    67 Buick Electra 225, 430 tire burner wildcat,
    +++if it ain't broke it's breaking+++
    Aug 2006
    Missouri
    94 Camaro Z28
    I'd say full bolt-ons before modding the internals, but that's me.
    There are plenty of companies out there (besides SLP) that have a good supply of heads and cams for the LT1.
    Resident Architect SS MPSTR's Avatar
    SoCal
    1997 Camaro Z28
    Quote Originally Posted by nobody View Post
    Thank you
    what is your budget, what are your goals, and what compromises can you live with?
    Michael
    2007 C6 ZO6 M6, cam/exhaust
    1997 Z28 A3 385 12-bolt big cam/LT4 heads
    1967 Chevelle SS M5 496 12/2006 CHP Feature
    Oct 2001
    Colorado
    95 Z28
    Quote Originally Posted by SS MPSTR View Post
    What Mike is trying to say is.... if you've got 10 or 20 grand to spend, contact Advanced Inductions and they'll hook you up with a killer set of heads, gauranteed to flow [email protected] lift
    SoCal
    1997 Camaro Z28
    Quote Originally Posted by 5.0THIS View Post
    What I'm trying to say is, if you've got $20k to spend, I'll sell ya my car.
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    i say stroker!!!!
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by 440 rwhp trans am View Post
    i say stroker!!!!
    That's a brilliant idea. A 383, or even a 396 stroker kit will net good gains with HUGE potential later on.
    Member jasonisdn's Avatar
    nc
    96 ss
    lmao 10 to 20 grand for a set of heads. man you really just like to joke to much. i have got to go pick mine up from them this week (just got the call today from phill) 210cc tfs heads completely built, cam, lifters,gaskets, push rods (measureing device included ) to check for proper length, intake ported and port matched to heads. i might have left some out but i dont think so. well i got all that for little over 3 grand. they are easy to talk to and just down right good people. their work speaks for itself.
    Aug 2006
    Missouri
    94 Camaro Z28
    That's not a bad deal at all. Especially for quality parts. Are you messing with the rotating assembly as well? Or just valvetrain?
    SoCal
    1997 Camaro Z28
    Quote Originally Posted by jasonisdn View Post
    Phil is the man.
    Oct 2001
    Colorado
    95 Z28
    It wasnt directed at AI so much. I'm just giving Mike a hard time...
    nc
    96 ss
    Quote Originally Posted by BlackLT1Z28 View Post
    Yes (long answer below lol)
    so far, unless jeff creech changes my choices, dragon slayer 3.75 crank, common .030 over bore, oliver billit rod, i was going -5cc je custom nitrous pistons, jeff says use cp (never even heard of them) then 2 stages of giggle gas, 125 outta the hole with 175 coming in once you hit 2nd gear and go WOT. still have atleast 4 to 6 months before i finish, at atleast maybe more. its nothing special just another 383 nitrous motor. also yeah the rearend and suspension have been delt with already. just hope the m6 rides for atleast the dyno tune and break in ,before it explodes. oh as far as CR we looking for 11.5 (piston .005 in the hole with a .027 gasket for the quench guys)
    Edit: hey 5.0 then "me bad, me bad" later
    Aug 2006
    Missouri
    94 Camaro Z28
    Sweet. What type of cam are you going with since your spraying?
    nc
    96 ss
    its a hyd custom, not a comp cam lobe design like alot of guys use and call it custom. i was told to keep the lobe specs to myself (you guys know how the industry is with trying to get each others secerts) i'll just say it isn't small and it has some decent over lap.
    have you seen the video with the 355 200cc , small solid roller cam red 96 ss yet?
    SoCal
    1997 Camaro Z28
  1. Question: Modifications
    By 1slowbusa in forum Internal Engine
    Last Post: 04-27-2011, 06:57 AM
  2. LS1 Modifications
    By BeerMan in forum External Engine
    Last Post: 05-06-2008, 02:50 PM
  3. what modifications for 17`s
    By 30thANNz28 in forum Wheels and Tires
    Last Post: 11-19-2006, 06:52 PM
  4. What are the first modifications done to your cars?
    By AKIRA in forum Almost Anything Goes
    Last Post: 10-31-2006, 02:42 PM
  5. modifications?
    By ls1kid20 in forum Camaro / SS
    Last Post: 02-12-2006, 11:46 AM
