Results 1 to 14 of 14
    Senior Member nitrox28's Avatar
    Lexingon Kentucky
    1997 Grand Cherokee
    1999 Firebird.
    Question Computer gurus help....How can I erase EVERYTHING from my hard drive?
    I want to erase everything including windows. How do I go about it? Actually, I'm running Windows XP Pro and I want to re-install Windows 98. When I run my restore CD, nothing happens. Windows XP is still there. Any thoughts? Is there something I can do in DOS? Thanks for any help!!
    Format.
    You need an actual system disc for Winders '98.
    Lexingon Kentucky
    1997 Grand Cherokee
    1999 Firebird.
    Well, Win98 is on my computer restore disk. Do you know how to format in DOS?
    Yes.
    Command....
    Format C:
    Restore disk is normally different than a system disk.
    Canby, Oregon
    1999 Camaro SS-M6 #1775
    AutoClave works the best. you can complete multiple passes on your hard drive to ensure that everything is gone. in most cases the formatting program on the Windows disk works just fine. but ive always used AutoClave. JMO.
    12.6 at 112
    Impounded 86 IROC-Z's Avatar
    Everything fiberglass
    2005 Amberlamps
    If you never want anyone to find your data, I suggest an acid bath, I hear that works best, because parts can still be salvaged if you use a drill.
    Member jacobyb's Avatar
    Los Angeles
    Impulse Blue Matallic
    2005 GTO
    What is the deal? Kiddie porn?
    Quote Originally Posted by jacobyb View Post
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Format C: does NOT erase anything....that is all
    But this will http://www.heidi.ie/eraser/download.php
    Canby, Oregon
    Try this link to get more information.
    http://staff.washington.edu/jdlarios...-discontinued/
    Ive used it many times and it works VERY good.
    Senior Member Corona-Extra's Avatar
    Houston Texas
    Black SVT & Silver WS6
    2003 SVT Cobra & 2002 WS6
    Put a really really big magnet next to it….. . lol
    No replacement for displacement.
    Peckerhead Knighthawk LS1's Avatar
    Loveland, CO
    1999 Trans am
    pull out the HD put in a microwave, set to 30seconds......go to bestbuy and get a new one
    Member Z27's Avatar
    Northern KY
    Green Red Black
    71 SS 00 SS 06 Impy SS
    Either one of these will work.
    Houston
    Burgundy
    2000 z28
    You need a boot disk with the fdisk command. This is a menu driven dos command that removes partitions. You will need to remove the nondos partition and then create a fat32 partition and make it active. Reboot with the boot disk again and then format and then install windows 98.
  1. computer gurus inside
    By Danger731 in forum Computers / Gaming
    Last Post: 05-25-2011, 08:08 AM
  2. Computer gurus----HELP!!
    By tommy303 in forum Almost Anything Goes
    Last Post: 12-21-2006, 09:02 PM
  3. Computer guys...I need a good external hard drive
    By Mike Hawk in forum Almost Anything Goes
    Last Post: 10-30-2006, 05:03 PM
  4. Computer gurus enter help :(
    Last Post: 08-28-2006, 08:15 PM
  5. computer gurus help needed
    By Firehawk1120 in forum Almost Anything Goes
    Last Post: 05-13-2006, 07:57 PM
