Results 1 to 20 of 40
    Member SS#337's Avatar
    Arlington, TX
    Onyx Black
    2002 SS
    02 SS Tire Combo Question
    I am thinking about one of the following combos with the Goodyear F1's:
    245/40ZR17 in front and 275/40ZR17 in rear
    or
    245/40ZR17 in front and 285/40ZR17 in rear
    or
    255/40ZR17 in front and 285/40ZR17 in rear
    Any thoughts?
    Why the 245 or 255 up front? The stock SS tire size is 275/40/17. The 285s would be good for the back though.
    Painted manta stripe
    Arlington, TX
    Onyx Black
    2002 SS
    I was thinking of a more bold muscle car stance. I guess it is the rear that gives it that look anyways huh. I had also thought about leaving the front stock tires on as fourth option. would there be nay handling issues with the wider tires on back? Any other thoughts are greatly appreciated. Thanks.
    Quote Originally Posted by SS#337 View Post
    I would stay with the 275/40s up front and go to 285/40s in the back like you mentioned. You are correct about the rears giving it the bold muscle car stance as well. No handling issues with 285s, you would be perfectly fine!
    Arlington, TX
    Onyx Black
    2002 SS
    Great. Thanks for your input!
    Glad to help, post pics when you get them mounted
    Arlington, TX
    Onyx Black
    2002 SS
    will do.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if you want a skinny/fatty look, then go 245/45-17 and 315/35-17. the sizes you are looking to get are different height and will kick off the ABS system.
    Semi confused here, how will the different heights kick off the ABS and I didn't think it was safe to put 315s on a 9.5" wide wheel?
    Thanks for explaining further
    orlando, fl
    2014 camaro 2ss/rs
    245/40-17 = 24.7" tall
    315/35-17 = 25.7" tall
    with the front tire being shorter. it will spin quicker than the rears. the computer picks this variance up as the front tires skidding. so, the ABS system activates. the ABS and brake light will come on the dash. when you go to apply the brakes, the ABS system starts pulsing the brakes because it thinks the front tires are skidding.
    as far as 315/35-17 being not safe to put on 9.5" wheels, don't believe that post on ls1tech. i rode around on 315/35-17 nittor DRs on my 17x9.5" wheels for a year. hell, at one point, i had 335/35-17 tires on them. that was pushing it.
    Thanks for the thorough explanation, that helps a lot. I don't believe much from tech for the record either. Just full of a lot of egos over there
    Pistol Pete '96 Z28SS's Avatar
    Cowboy Country Stillwater, OK
    Bright Rally Red
    1996 Camaro SS
    IMO i would go with a 275/40/17 all the way around. i miss not being able to rotate my tires. Also i would look into a Kumho or maybe a yoko tire. i wasnt too pleased with my F1's
    --------- Chris - 1996 Camaro Z28SS #1524 ---------
    LT4 Cam Kit | Comp Lifters/PR's | Jet Hot LT's & ORY | Corsa RSC Exhaust | SLP Bilstiens | S-C/D Rotors | 1LE Elbow | !EGR/AIR
    madZ tune | 17x11 Chrome ZR-1's | Berger Panel | Fillins | BMR STB | Autometer A/F & Trans Temp | !Mouldings | Zaino
    Arlington, TX
    Onyx Black
    2002 SS
    I have the SLP chrome 10 spoke rims so you say I can go up to 315 without having to buy bigger rims for the rear? I thought I would have to go to an 18" to fit the 315s. I am looking to keep the rims I have now, just get the "fatty" look in the back.
    orlando, fl
    2014 camaro 2ss/rs
    on a 9"wide wheel, depending on brand of tire, it will distort the tread pattern by being a bit on the narrow side for a 315. i have seen people with 315 on 17 x 9 wheels. there is a point is diminishing returns.
    Arlington, TX
    Onyx Black
    2002 SS
    which means what exaclty...what will be diminished - just the tread wear? I am new to this arena...just trying to understand what will work here. I just want to get that fat stance in the rear without going to a bigger rim or meesing up anything ie ABS (thanks for that info). So what would be my best combo? Don't really care about rotating tires that much at this point. Oh and this is a daily driver - if that matters. - Thanks.
    orlando, fl
    2014 camaro 2ss/rs
    when the tire gets too wide for the rim, it will distort the tire. this can cause handling issues. what happens is when the TREAD width of the tire exceeds the rim width, it will curve the tread.
    for you with your stock wheels i would do this
    245/45-17 front
    275/40-17 rear
    both are 25.7" tall and don't affect the braking system.
    Arlington, TX
    Onyx Black
    2002 SS
    ok, sounds good. Thank again!
    btw I was thinking about the Nitto's/NT 555 EP or the BFG's/g-Force KDW, whatcha' think?
    orlando, fl
    2014 camaro 2ss/rs
    KDW are good tires. haven't read up on the EP.
    Arlington, TX
    Onyx Black
    2002 SS
    ok. thanks.
    2002 Onyx Black Camaro SS, m6, SLP Cold Air Induction, SLP Lid, K&N Air Filter, SLP 160 Stat, SLP MAF Type B, Y-Pipe Dual Cat, Out & Tip Exhaust, SFC, STCB, PHB w/HCA's, Rear Lower Skip Shift Harness, Hyper-Tech LS1 Power Programmer.
    Another vote for KD and KDW tires, EXCELLENT
  1. Question: Wheel & Tire Combo
    By 98ramairguy in forum Wheels and Tires
    Last Post: 04-25-2014, 09:47 PM
  2. Rim Tire combo
    By 2000dreambird in forum Wheels and Tires
    Last Post: 04-06-2014, 11:02 AM
  3. Quick zo-6/tire combo question
    By Phil's camaro in forum Wheels and Tires
    Last Post: 10-23-2009, 04:13 AM
  4. New Wheel/Tire Combo!
    By Sassy Cassie in forum Southern Members
    Last Post: 06-21-2006, 01:48 AM
  5. wheel/tire combo
    By adham in forum Wheels and Tires
    Last Post: 12-26-2005, 02:25 PM
