Results 1 to 20 of 24
Thread: my blinker is not working??
11-20-2006, 09:59 PM #1
- Oct 2005
- Ontario, CA.
Hugger Orange- 1999 CAMARO SS
ive checked all the fuses;lights;turn signals everything is working except for my left turning blinker?
anybody had this problem?
thanks in advance.
Hector
11-20-2006, 10:03 PM #2
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
maybe a ground wire?
12.6 at 112
11-20-2006, 11:10 PM #3
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
Light bulb burnt out?
11-21-2006, 12:01 AM #4
does it not blink or not light up? Is it the front or back or both? Does it look like moisture is getting into the lense?
11-21-2006, 12:37 AM #5
- Nov 2006
- Baytown
blue- 1998 transam ram air
That used to happen to my 98 ram air (fog lights)....I had to replace the whole assembly.....now no problems.... between moisture and loose wiring it was a
11-21-2006, 01:02 AM #6
if your day time running light burns out then the blinker will not work
11-21-2006, 01:09 AM #7
- Nov 2006
- Baytown
the bulbs kept burning out in my trucks running lights so we just didn't put them back in and the blinkers work.....Is there a difference?......
11-21-2006, 02:59 AM #8
- Nov 2006
- Indianapolis
Wendy,Your trucks running lights are most likely not the same as the turn signals.
Hector, double check the brightness of all your lights. Put your hazards on and check the lights. Your hazards use the same bulb/filament as the turn signal. All lights need to work, and be bright. I have seen people install thier own lights and jam them in the wrong way and cause all kinds of problems.
11-21-2006, 07:35 AM #9
- Jun 2006
- Charlotte, NC
08 Mustang GT/CS Blue- 2002 Trans Am WS6 traded
If you've checked all the bulbs, including rear, and they are good I would check the socket that isn't working next. It seems commom for moisture to get in there and corrode it. Do a search...several posts in the last couple months with similar problems.
11-21-2006, 07:48 AM #10
the sockets are known for going bad. check it to see if it is burned up or corroded...
95 Exploder
01 R1 coming?
11-21-2006, 06:06 PM #11whsGuest
11-21-2006, 11:19 PM #12
- Jun 2006
- Charlotte, NC
Look here... Also should note that I went back and heeded the advice of 'Orcus' (sp?) in this thread concerning butt connector vs. solder; would rather go through a little trouble now than have a headache later.
http://www.ls1.com/forums/showthread.php?t=32372
11-26-2006, 04:52 AM #13
11-26-2006, 11:52 AM #14
Simply re-fill yer blinker fluid?
http://kalecoauto.com/index.php?main...&products_id=6
11-26-2006, 12:11 PM #15
- Nov 2006
- Cologne, Germany
Navy Blue Pearl- 2000 Camaro Z28
Sorry i can't help, but Blinker is the German word for Turnlight.
He the blinker fluid is cool, i need it
11-26-2006, 02:38 PM #16
- Aug 2006
- Michigan
Black- 98 T/A
If your connectors are corroded bad, I used non chlorinated brake cleaner or electrical cleaner to clean out the old bulb grease. I then took a syringe full of muriatic acid and let it sit in the connector for about 20-30 seconds. dump it out and respray the cleaner to flush out the acid residue. Allow to dry, replace bulb grease and bulb. Works great for the headlight/motor connectors as well. Ensure you replace the headlight plug female side up with the attachment prong and hole on the fenderwell to prevent water from sitting in the plug.
11-26-2006, 10:51 PM #17
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
get a replacement socket if after replacing the bulb doesnt work.
11-26-2006, 11:12 PM #18
11-27-2006, 12:04 AM #19
- Nov 2006
- Cologne, Germany
I think???? Nobody !!!!!!!!!
11-28-2006, 08:18 AM #20
blinker fluid should only be added every 50k miles or when you re-torque the muffler bearings.
brake light and blinker arent working?
By mikey gavin in forum Firebird / WS6Replies: 24Last Post: 06-25-2011, 01:23 PM -
Blinker not working
By freddy_caprice in forum Firebird / WS6Replies: 16Last Post: 09-12-2009, 10:04 AM -
right blinker clicking fast but not working?
By ggino85 in forum General HelpReplies: 11Last Post: 08-19-2009, 07:41 AM -
Blinker not working - please confirm problem
By jrummi in forum General HelpReplies: 6Last Post: 01-14-2009, 06:07 PM -
right blinker not working... help
By y2kformula in forum General HelpReplies: 19Last Post: 12-10-2005, 04:14 PM
