Results 1 to 1 of 1
11-14-2006, 05:30 PM #1Junior Member
- Nov 2005
- Diamondhead, Mississippi
- iTrader
- 0
Black- 1998 Chevy Camaro SS
1999 Ford Mustang Stage 2 Roush/tons of upgrades. located in MS
For sale or trade.
Sell out right for $15,000.
Trade for LS1 cars only, unless offering cash and trade.
1999 Ford Mustang Roush Stage 2 #3369, with all of stage 3 components and then some..
Cloth interior, Power door locks and windows. Very Clean!
Engine:
Ford motorsports block with a full VT Engine assembly: Cobra crank, Manley H Beam rods, Diamond 19CC pistons, Moly Rings, Patriot Stage 3 heads with Comp Cams 278 cams, ARP Head/Main studs, ARP Rod Bolts, FRPP Dampner, ARP Dampner bolt. Vortech V2 polished supercharger, 3.60 and 2.85 pulleys, Reichard Racing sheet metal intake manifold, 80mm throttle body, NGK V2 plugs, 03 Cobra pumps with Kenne Bell boost-a-pump, FRPP shortie Headers, UPR O/R X pipe, flowmaster mufflers. Cobra oil pump, 180* thermostat, all new gaskets and seals. All bearings were replaced.
Transmission:
Stock T-45 ith Fandanza Flywheel , Spec Stage 3 clutch, Tri-Ax Shifter,
Rear End: Mach 1 rear end with 355 gears, Aluminum Driveshaft,
Interior: Speed glow tinted gauges.. boost/vacume oil pressure air/fuel, Alpine Cd player. The rest is stock, but very clean.
Exterior: Roush Body kit, 18 inch roush wheels with new Michelin Tires. HO Fibertrends 4 inch cowl hood, tinted head lights.
Electronics..
SCT programmer.
Car has 110,000 but engine only has a few thousand.
The engine was dyno tuned out of New Orleanse, LA at Shreve Automotive. Put down 432.6 HP at 10 psi. It needs to be retuned with the 16 psi pulley and a front mount intercooler, and could do well over 500hp to the wheels.
Contact Eric at 228-363-0586
Email me at [email protected]
AIM at Redirwol1
smashed a roush stage 3
By dpinson in forum Kill StoriesReplies: 10Last Post: 01-28-2008, 03:42 PM -
Whipple 07 Stage 1 Roush
By Stone in forum Kill StoriesReplies: 6Last Post: 12-10-2007, 04:26 PM -
Roush stage 2 how would i do
By 180ls1 in forum Kill StoriesReplies: 20Last Post: 10-31-2007, 09:47 AM -
CBR 600RR vs. Roush Stage 1 vert
By Z28Camaro010 in forum Kill StoriesReplies: 26Last Post: 09-08-2006, 04:50 PM -
Roush Stage 2
By NE98LS1 in forum Drag RacingReplies: 6Last Post: 01-30-2006, 09:56 AM
