    Aug 2006
    CT
    1986 Buick Grand National
    Truck coil to replace the OEM coil
    Greetings all,
    I hear that you could swap out the OEM coil with a Truck coil, because the Truck coil is slightly more powerful.
    I have a two style truck coils (LS7?). But the primary side connector is a different connector than the OEM. Is there a truck coil that has the same connector has the OEM? Or do I need to cut and splice? Maybe I have the wrong truck coils.
    Bragg NC
    Met. Sunset Orange
    01 SS
    I would not reccomend cutting and splicing. If the coils dont fit then they dont fit. On the same note you wont notice a different with the coils unless your running heavy mods so save the cash and mod elsewhere.
    J
    Aug 2006
    CT
    Thank you for the reply.
    God Speed, Fred Carrado Jr.
    "[email protected]"
    "http://www.mindspring.com/~fc227/.htm"
    203-453-6571 ext 342
    Moroso Performance
    86 Grand National
    12.252 @ 108.56 MPH (to be updated soon)
    C16 & 20# of boost
    Aug 2006
    CT
    What is being used for an ignition upgrade on the LS1 engine? I know MSD is selling after market coil. But I also read that the truck coil was also another upgrade. But it has a different connector on it (LS7?).
    Bragg NC
    Met. Sunset Orange
    01 SS
    Msd, does offer a coil pack kit for right under 600.00, Also if you decide too do the upgrade i would reccomend taking a look at the plugs and wires so u do get the max output.
    J
    Oklahoma City
    00 LS1, WS6, V8 Gremlin
    96 & 98 GTPs, 64 'Cuda
    In my opinion the factory coils are fine unless you're introducing boost, you could help by using the proper plugs and wires.
    I highly recommend reading this website in its entirety, I've used their wires for decades with excellent results and no problems over time: http://www.magnecor.com
    Good plugs to run in LS1 engines are AC-Delco 41-932 or Autolite XP5245
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by fc227 View Post
    Greetings all,
    Well actually wonderfull GM has contracted out the coils multiple times.......There is a total of 5 different coils used on the LS motors...ALL HAVE DIFFERENT CONNECTORS!!!!! And there is 3 different mounting styles also. MSD ONLY MAKES 2 VERSIONS!!!
    Stock coil has more power than you'll ever need unless your adding LOT'S of cyl. pressure; such as a 200 shot or 8psi or more of boost.
  1. Wanted: SIR Coil
    By MrKid in forum Parts Wanted / Trade
    Last Post: 07-27-2010, 05:51 AM
  2. Truck coil install in pics
    By sjsingle1 in forum External Engine
    Last Post: 07-20-2010, 01:05 AM
  3. coil pack ?
    By t-rock in forum LT1
    Last Post: 12-28-2008, 05:48 AM
  4. Question: LS1 coil help
    By wmr71 in forum General Help
    Last Post: 07-25-2008, 09:08 PM
  5. Stock front coil springs off 98' SS with 1/2 coil removed
    By KIXASS in forum Parts For Sale / Trade
    Last Post: 07-31-2007, 06:57 AM
