Results 1 to 10 of 10
    Car RamRod 98Camarod's Avatar
    Feb 2006
    Goose Creek, SC/ NWS
    Green
    1998
    No start after throttle body port
    Today I had my throttle body ported and installed. I went to crank it and thats all it did. Everything was hooked up and the blade opened smoothly. WTF
    MAF sensor plugged back in?
    Feb 2006
    Green
    1998
    Yes, everything was plugged back in. I am not getting any fire now. Any ideas? I checked all the fuses I could find and all were good. Any fusable links that might have happened to burnt or hidden fuses for coils?
    Battery just crap out?
    Can't think of much that can go wrong if everything got connected properly.
    Feb 2006
    Green
    1998
    It cranks over strong, It is not getting fire.
    When you turn the key to the on position...can you hear the fuel pump prime?
    Are you getting spark?? What if you try to turn it over with a plug wire off?
    Lowered, HID's, tinted.
    Retired Outlaw Sum Bitch
    Did you dissconnect your negative batter cable before the swap? If not you most likely blew a fuse....which one...who knows.....check all of em...
    Feb 2006
    Green
    1998
    I checked all the fuses, there are three spots, two under the hood and one in the compartment and I didnt find anything. There is fuel pressure and everything is hooked up correctly. There is no spark though, blows my mind.
    Feb 2006
    Green
    1998
    I cleared the pcm and rechecked the fuses and now I do not have power to the eng ctrl and others in the second box. There is no power going to the bottom either. WTF? There are only a few fuses in the box that have power, the pcm ign and the 10a fuse. WTF? how do they receive power then?
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    check all your ground straps for that box, there should be one that goes to the backside of the alternator. Check and clean the positive battery cable that connects to the fuse box as well
  1. Throttle body port n polish
    By Ramairgod84 in forum Corvette
    Last Post: 08-10-2009, 01:38 PM
  2. port n polished throttle body
    By Ramairgod84 in forum General Help
    Last Post: 04-16-2009, 02:06 PM
  3. port n polished throttle body
    Last Post: 04-07-2009, 10:07 AM
  4. FS: Port and Polished Throttle Body P&P TB
    By ApexVIII in forum Parts For Sale / Trade
    Last Post: 12-30-2007, 08:02 AM
  5. WTB port and polished Throttle body
    By Justin23454 in forum Parts Wanted / Trade
    Last Post: 12-26-2007, 06:17 PM
