Results 1 to 2 of 2
    Member mvvette97's Avatar
    leon iowa
    1997 corvette 00 WS6 TA
    How do I get taller install height?
    I'm sure you have read about my 918 springs breaking. I hear that the 918 spring needs to be set up at 1.80 so I checked mine the best i could and it seems to be around 1.631. How do i change it so it will be around the 1.80? Is there differant shims i can get?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    what did you check it with?
    if really are at 1.631 installed height, the way to get more is to get offset keepers, offset retainers, .100 longer valves, or grind the valve pocket in the head deeper.
  1. Taller oil filter?
    By 1st TA in forum General Help
    Last Post: 11-16-2011, 04:53 AM
  2. Question for anyone around 6'5" or taller...
    By StuntmanMike in forum Almost Anything Goes
    Last Post: 05-03-2011, 05:04 PM
  3. Measuring Correct Install Height - Pre-Check - CHP Step By S
    Last Post: 11-30-2010, 04:20 PM
  4. Taller tire?
    By bigbucks39 in forum Wheels and Tires
    Last Post: 03-04-2008, 08:12 AM
  5. Taller WS6 airbox base on SS?
    By 2000M6SS in forum Camaro / SS
    Last Post: 12-05-2006, 09:15 PM
