Thread: Needles in pan...
11-01-2006, 05:49 AM #1Junior Member
- Sep 2006
- Georgia
red black- 98Z28
Needles in pan...
Hi guys, new to the forum but have tried to read all posts related to this issue. Got my 98Z28 used two years ago with 85,000 miles on it. Now after numerous oil changes I find a needle attached to drain magnet. Car is not ticking. I have put about 7,000 miles and two oil changes on car after finding needle. Still no ticking or any more needles. Just got through with a 500 mile trip where I would average 80 mph for a couple of hours at the time , no problems. Car still getting around 27 mpg on open road and averaging 23 mpg as a daily driver around 80 miles a day. So am I pushing my luck waiting until I need a tune to do(or check) the rocker arms? Have had several people tell me to wait for tune or until I hear a ticking. Also the TSB recomends pulling and cleaning pan, what do you think? I've only seen one instance where any real damage was caused by this. So what would you do?
LS1 4L60E sitting at about 140,000.
11-01-2006, 09:55 AM #2
um, if you have needle bearings in the oil pan, don't wait until you hear a ticking. you may end up bending pushrods and possibly damaging the heads because of it.
and why would you wait for a tune to do rockers?Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
11-01-2006, 02:33 PM #3Member
- Oct 2005
- RI
Mag Red- 2002 Vette
I wouldn't wait either, especially if you plan to return to stock rockers. They are not expensive compared to the problems you could run into with a catastrophic failure or if a needle were to find its way into somewhere more problematic.
11-01-2006, 02:51 PM #4
Replace your rockers asap. Also do clean your oil pan.
FINALLY! 1993-2002 Gauge Needles... "S86 Needles
By 6LITEREATER in forum Appearance SectionReplies: 96Last Post: 01-16-2010, 07:00 AM -
Aftermarket Gauges Needles question
By squeals99 in forum Stereo and ElectronicsReplies: 2Last Post: 01-19-2008, 03:17 PM -
TRANS AM GUAGE NEEDLES 98-02 or cluster
By greatwhiteZ28 in forum Parts Wanted / TradeReplies: 0Last Post: 03-22-2007, 11:30 AM -
where to buy orange guage needles from TA to put on Z?
By greatwhiteZ28 in forum Camaro / SSReplies: 3Last Post: 02-25-2007, 03:47 PM
