Results 1 to 20 of 22
Thread: Front brake rotors warped again
10-31-2006, 08:48 PM #1Junior Member
- Oct 2006
- Southern California
Red- 1999 Z28 Convertible
This is the second time that these Bauer rotors are wraped. Soon after I bought the car the rotors warped I had them ground like a flywheel. They lasted about 5000 miles. I am using metallic pads with stock calipers. IS it the metallic pads or the calipers? I have read on here that the fix is the Corvette rotors. Why is this. Any good way to get these things staright again?
Thanks, Mrbob2
11-02-2006, 08:26 PM #2Crazy Canuck !
- Jun 2002
- Montreal, CANADA
just get good old not expensive Brembo blanks OEM replacement.
11-02-2006, 10:05 PM #3
blanks from kraegan, 10 k n no problems
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
11-02-2006, 10:14 PM #4Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Use ceramic pads instead.
I also use Auto Zone Rotors
11-02-2006, 10:23 PM #5Senior Member
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
dont want to steal the thread or anything. but mine are warped also.
does anyone know how much the corvette ones are?1999 Camaro SS/ Pewter/ #1775 - LS1 6-speed - Predator 3 Custom Tune - Pro 5.0 - LS7 Clutch - 3.90's - Koni's - Strano Springs and Sway Bars - SFC's - Full UMI Chassis and Suspension - LS6 Intake PnP TB - ARH LT's and Kitty Ran Away - Magnaflow.
12.6 at 112
11-06-2006, 06:48 AM #6Last of the Breed
- Columbus, OH
Pewter Metallic- 2002 Firebird Formula
Mine are also warped (on the 3rd set already). Not nearly as bad as the first 2 times, but I've decided GM rotors aren't gonna cut it, period. Anyone got any suggestions? Is slotted/drilled the way to go? I have easy access to an Auto Zone... I hear theirs are satisfactory...
11-06-2006, 07:40 AM #7Junior Member
- Mar 2006
- Baltimore
Black- 2000 Trans-Am
Just had F Body Central in Baltimore do 4 POWERSLOT Slotted rotors and new pads on all four corners.
Brakes normally if you drive normally, unless you really push into the pedal then it starts to brake hard. With some agressive driving, once you get some heat in the pads, it brakes extremely well. No warping to speak of, but then again, it's only seen about 1000 miles since then and mostly on the highway....but it slows very smartly from 110!!! Waaaayyy better than stock.
11-06-2006, 10:50 AM #8Last of the Breed
- Columbus, OH
What did that run you?
11-07-2006, 09:13 AM #9Junior Member
- Mar 2006
- Baltimore
nothing....but we had an...umm... agreement
11-07-2006, 09:30 AM #10Junior Member
- Aug 2006
- Mickleton, NJ
Pewter- 2002 WS6 Trans Am
I agree with the Brembo OEM replacements. I had a '98 Firebird Formula with the same problem. The rotors warped and I had them turned once with same results. I then went to the Brembo OEM replacement rotors with ceramic pads and had no problems. I have since sold the car and bought an '02 Trans Am. So far so good with the original rotors with 28,000 miles on the car but I am waiting.
11-07-2006, 09:34 AM #11
Hey, Brembo's or even the Autozone rotors are TONS better than the factory rotors, you won't regret it...
Also fyi, blank rotors stop better, more surface area...The Black 2001 SS #5697
T-tops, 6-spd/B&M ripper, ARH LT's/GMMG/CME, Volant, Koni DA's & GC coilovers, Strano frt & rear sways, G2(SFC's w/v-braces, STB, adj PHR), Wilwood 6-piston red calipers frnt brakes w/13" 2-pc rotors, RKSport(clear front & rear corners, c-f grill), chrome Z06 wheels
11-07-2006, 12:02 PM #12Last of the Breed
- Columbus, OH
I decided I'm going with AutoZone's Duralast rotors. Talked to a few people about them and the general consensus is they'll be fine... a lot better than the GM rotors, anyway.
I figured blank rotors stopped better... I was just thinking the metallic pads were generating too much heat. I'll give the Duralast rotors & ceramic pads a go & see how they fare.2002 Firebird Formula
Pewter Metallic | Ebony cloth
K&N filter | Magnaflow | Eurolights Xenon kit | Clear LED Side Markers
11-08-2006, 02:21 PM #13
11-12-2006, 05:09 PM #14Bad habbit- Smoking Fords
- South Florida
Sunset Orange Metallic- 2001 Camaro SS
I doubt that. I have used slotted Brembo rotors for 110K on my car with suoerior results. Brembo clearly states that it's OEM replacement blanks are not for high performance driving of any sort. They only recommend their slotted rotors for autocrossing or road racing.
2001 SS - 430 RWHP 412 RWTQ
6 spd, FIPK, Corsa exhaust, LS7 clutch, Dart Pro PP LS1 heads, custom 220/224 cam, Kooks LT's. Ported TB, Full suspension, C5 ZO6 brake upgrade.
11-12-2006, 05:38 PM #15Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
Brembo blanks here...just got em from Tirerack. Went with HPS Hawk pads and I love the setup so far
11-13-2006, 04:43 AM #16Bad habbit- Smoking Fords
- South Florida
The Brembo blanks are a great deal for an excellent product. I would recommend the Satisfied Grand Sport 6 Ceramic high performance pads in the front as they have a much better initial bite than the Hawk HPS pads.
12-07-2006, 08:46 PM #17
just go get a set of Baer Eradispeeds. They are the best bang for the buck and have a lifetime limited warranty against warpage. I had them on my 98 Z28 A4 and abused the hell out of them on the German Autobahn, tracks and street. They NEVER warped. They look bad-ass too. Can't beat it. When my stocks warp on my '02 WS6, I'm getting the Eradispeeds for this car too.
THEN: 98 Z28 A4 2.73 FRA STB SFCs LCA Relocators Lowering Springs DAPHR SLP Bilsteins Descr. MAF EGRCut-off Lid Eradispeeds - Daily Driver includ. 3 yrs on the German Autobahn!
NOW: '02 WS6 M6 LOTB BMR STB, SLP bolt-in SFCs, !spare/jack, SLP lid, Battery Relocation
12-07-2006, 08:57 PM #18Bad habbit- Smoking Fords
- South Florida
Eradispeeds are way overpriced, you will do alot better with several different brands including Brembo or Power Slot. For the price of the front Eradispeeds you can but front and rear rotors. I still prefer (for the budget minded) the Brembo blanks (4) at about 1/2 the price of just the fronts in an Iradispeed.
12-14-2006, 07:55 AM #19
Where do you guys buy these "blank" Brembo's from?
12-16-2006, 06:53 AM #20
Question: Cross Drilled and Slotted Front Brake Rotors
By WS6ICK in forum General HelpReplies: 3Last Post: 05-07-2009, 07:21 PM -
Warped Brake Rotor-Which One?
By silverbird22 in forum General HelpReplies: 10Last Post: 03-09-2008, 06:01 PM -
Factory Brake Rotors (front and rear) $40
By Chad97z in forum Parts For Sale / TradeReplies: 0Last Post: 11-12-2007, 12:26 PM -
will warped rotors make your car drive bad ?
By Speedy_Gonzales in forum General HelpReplies: 3Last Post: 10-28-2007, 06:16 PM -
front or rear warped?
By z28rktec in forum Suspension and HandlingReplies: 2Last Post: 10-28-2006, 02:27 AM
